How deep a bend? I built a roller based brake that might be super sized for your use but I think that bandit 1/8 in aluminum would be difficult if it has any alloy in it. As with most request like this, we don't have enough information to really recommend a solution. At that thickness and assuming that it is a ridged structure I would look at welding it unless you will be doing a whole bunch of them.
I suppose that you could build a power or manual hydraulic open end "O" punch that you could walk the metal through to get the length that you need.
Good luck
Lowell
