Results 1 to 5 of 5
Thread: Home made Belt grinder / sander Anti Static strap
  1. #3
    neilg4dbn's Avatar
    Aug 2021
    Yorkshire, UK
    neilg4dbn's Tools
    Nice solution with using the magnet as an emergency breakaway. For best electrical safety, the usual solution is to have a resistor in series with the drain wire so that you won't get a shock if there is a fault with the machine electrics. A value of around 1 megohm is sufficient to drain away static charge while protecting against fault currents. Most of the wristbands I've seen have a resistor or use a carbon strip or something to provide the resistance.
  2. The Following 2 Users Say Thank You to neilg4dbn For This Useful Post:
    clavius (Dec 17, 2021), FEM2008 (Dec 20, 2021)
