a great build thanks for sharing.
PowerMk (Apr 6, 2019)
I only see 1 one thing I might comment on and this is just from a personal perspective having ran 2 wheeled tractors in the past that nearly ran me down.
the reverse gear if possible should be made so that in order to back up the clutch should be designed so that you must hold it engaged.
This is quite bothersome to have to constantly hold a clutch in forward position but when reversing it is a matter of safety a linkage could be made to over center in the forward position to allow constant engagement but would not over center in reverse this also would mean a strong enough spring to hold the clutch disengaged would be need in the linkage
Just an observation not a criticism you have built an amazing little tractor just like all of your other projects.
Vyacheslav.Nevolya (Apr 5, 2019)
Thanks Vyacheslav.Nevolya! We've added your Pull Tractor to our Farm and Garden category,
as well as to your builder page: Vyacheslav.Nevolya's Homemade Tools. Your receipt:
Vyacheslav.Nevolya (Apr 7, 2019)
tbdl (Apr 14, 2019)
