Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 42
Thread: Homemade two wheel behind tractor
  1. #21
    a great build thanks for sharing.
  2. #22
    Feb 2015
    Manitoba Man's Tools
    Excellent work as usual sir! Congratulations on a job well done. Do I see a Ural transmission? Bob from 🇨🇦
    Supporting Member Vyacheslav.Nevolya's Avatar
    Dec 2015
    Ukraine
    Vyacheslav.Nevolya's Tools
    Quote Originally Posted by drivermark View Post
    Very impressive "doityourselfullness", did you by chance also make the gears that went in that gearbox ?
    I do not manufacture a gear. I used gears from broken car and motorcycle gearboxes.
  4. #24
    Dec 2015
    Ukraine
    Quote Originally Posted by Manitoba Man View Post
    No, the transmission of the motorcycle Dnieper
  5. #25
  6. The Following User Says Thank You to Vyacheslav.Nevolya For This Useful Post:
    PowerMk (Apr 6, 2019)
  7. #26
    I only see 1 one thing I might comment on and this is just from a personal perspective having ran 2 wheeled tractors in the past that nearly ran me down.
    the reverse gear if possible should be made so that in order to back up the clutch should be designed so that you must hold it engaged.
    This is quite bothersome to have to constantly hold a clutch in forward position but when reversing it is a matter of safety a linkage could be made to over center in the forward position to allow constant engagement but would not over center in reverse this also would mean a strong enough spring to hold the clutch disengaged would be need in the linkage
    Just an observation not a criticism you have built an amazing little tractor just like all of your other projects.
    Vyacheslav.Nevolya (Apr 5, 2019)
  9. #27
    Thanks Vyacheslav.Nevolya! We've added your Pull Tractor to our Farm and Garden category,
    as well as to your builder page: Vyacheslav.Nevolya's Homemade Tools. Your receipt:
  10. The Following User Says Thank You to DIYer For This Useful Post:
    Vyacheslav.Nevolya (Apr 7, 2019)
  11. #28
    Dec 2015
    Ukraine
    Making a plow from an old propane balloon
    Homemade two wheel behind tractor-20190406_103848.jpg Homemade two wheel behind tractor-20190406_164401.jpg Homemade two wheel behind tractor-20190406_164318.jpgHomemade two wheel behind tractor-20190406_164329.jpg
  12. The Following 6 Users Say Thank You to Vyacheslav.Nevolya For This Useful Post:
    Andyt (Apr 10, 2019), Inner (Apr 10, 2019), Jon (Apr 9, 2019), Ken Koch (Apr 10, 2019), Seedtick (Apr 10, 2019), sossol (Apr 14, 2019)
  13. #29
    Dec 2015
    Ukraine
    Soon the first tests
    Homemade two wheel behind tractor-20190409_162900.jpg Homemade two wheel behind tractor-20190409_162913.jpg
  14. The Following 2 Users Say Thank You to Vyacheslav.Nevolya For This Useful Post:
    Andyt (Apr 10, 2019), Seedtick (Apr 10, 2019)
  15. #30
    Aug 2016
    wizard69's Tools
    Just in time for spring too!
    By the way very nice build! These sorts of tractors use to be popular but are hard to find anymore.
    Quote Originally Posted by Vyacheslav.Nevolya View Post
ID:	29190 Click image for larger version.
  16. The Following User Says Thank You to wizard69 For This Useful Post:
    tbdl (Apr 14, 2019)
