Results 1 to 6 of 6
Thread: Honing discs for bench drill
  1. #4
    Perth Ontario Canada
    You may have seen that some whetstone manufacturers offer profiled honing wheels for their machines. They are made of leather. They aren’t cheap!
    Medium density fibreboard seems to have the same density, take up the polishing compound just as well and are cheap as chips to make. Even if you don’t have a holesaw, if you run the blank on an arbour in the drill, it is easy to shape the spinning disc with a rotary rasp, even a hand rasp.
    You must run it at a slow speed, with the edge away from the direction of rotation, as I am sure you will recognise.
    Nice. Done this for carving tools in MDF used as a contoured strope. I use the chisel to make the correct shape. Your idea is faster! I like it!!
  2. The Following 4 Users Say Thank You to mwmkravchenko For This Useful Post:
    emu roo (Dec 1, 2025), luvmygto (Jan 31, 2022), Philip Davies (Jan 31, 2022), Toolmaker51 (Feb 10, 2022)
