[QUOTE=1940LaSalle;250893]
Quote Originally Posted by philippacificnw View Post
This is GREAT! FOR the benifit to OTHERS, I was "fairly sure" the liquid was XYLENE, that, for ME was PROVEN, by simply turning ON Closed Caption !!!
My "timing" to watch this: Major Head ACHE, I turned OFF the Music!
following the VIDEO, I had to "rewind" to see it. I made SCREEN CAPTURES of the major scene changes !!!
the WHITE (PVC) did show the Air Heat GUN & FIRE BRICK !
the Black (¿ polyethylene?) NO heat source Shown BUT LOOK carefully at the bottom of CAN there were Signs of Heat applied.
[FONT="]philip, from the Great Pacific NorthWET, Oregon, USA[/FONT]
It would have been helpful to have the solvent identified specifically as xylene, rather than having to rely on closed captioning. Also, the use of a heat gun with a flammable solvent like xylene is not the best idea: mixed xylenes, as one often gets at a hardware store, have a flash point of ~90-100°F. A safer way to apply heat would be to set the can with the plastic shreds and solvent in a bath of boiling water.
The boiling point of xylene is 130-144 degrees, your bath won't help.
