Results 1 to 8 of 8
Thread: How to make a tool post grinder for your lathe from a palm router.
    Supporting Member Cazual Haze's Avatar
    Apr 2023
    United Kingdom
    Cazual Haze's Tools
    This is how I turned a very cheap palm router into a pretty useful toolpost grinder for my lathe.
    I was surprised at just how good the results were from grinding with this tool.
    If you do make one please make a safety guard.
    Cheers
  2. The Following 7 Users Say Thank You to Cazual Haze For This Useful Post:
    emu roo (Jun 12, 2025), EnginePaul (Apr 17, 2023), Jon (Apr 17, 2023), Lets Roger That (Apr 24, 2025), olderdan (Apr 18, 2023), WmRMeyers (Apr 18, 2023), xraybiker (Apr 19, 2023)
    Thanks Cazual Haze! We've added your Tool Post Grinder to our Grinding category,
    as well as to your builder page: Cazual Haze's Homemade Tools. Your receipt:
    olderdan's Tools
    Nicely made attachment
    When cyl grinding you need to rotate the work in the opposite direction to the wheel, this stops the loose grit and debris (and there always is some) from being crushed back into the work. You will get a better finish that way. I dont grind in the lathe but instead I use a CBN tipped tool which will cut 65 Rockwell hardened tool steel for better than ground finish.
Size:  4.7 KB How to make a tool post grinder for your lathe from a palm router.-after.jpg
  6. The Following User Says Thank You to olderdan For This Useful Post:
    drivermark (Apr 6, 2024)
    WmRMeyers's Avatar
    Dec 2014
    WmRMeyers's Tools
    Quote Originally Posted by Cazual Haze View Post
    Cheers
    Rule #1 for Poor Welders. If nobody can see the poor welds, you're not as poor as you think you are. I'm a poor welder, too, but my welds are usually quite strong. Which would leave much room for grinding!
    Bill
    Congratulations Cazual Haze - your Tool Post Grinder is the Homemade Tool of the Week!
    This is a very well thought-out build (part one is here), and it was built using some older homemade tools, including a tailstock die holder and a diamond wheel dresser.
    Acid Vat by Frank S
    Keyway Cutter Attachment by LMMasterMariner
    Track Guide Plates by thehomeengineer
    Cylinder Square by PaulsGarageProjects
    Drilling and Countersinking Bit by mr_modify1
    Micrometer Cheek Pieces by Occasional machinist
    Explosives Cargo Box by Frank S
    Marking Gauge by Make Things
    Carbide Insert Holder by Improvised DIY
    Work Table Brake by Frank S
    Cargo Box Mount by Frank S
    Mini Hand Grinder by My MiniCrafts
    Cazual Haze - we've added your tool entry to our All Homemade Tool of the Week winners post. And, you'll now notice the wrench-on-pedestal award in the awards showcase in your postbit, visible beneath your username:
    And, you'll be receiving a $100 online gift card, in your choice of Amazon (US-only), PayPal, or bitcoin. Please PM me your current email address and award choice and I'll get it sent over right away.
    Nice work!
    Apr 2023
    United Kingdom
    Cazual Haze's Tools
    Wow thank you stunned people think the grinder is a worthy contender.
    casual.haze@gmail.com
  10. #7
    Apr 2023
    United Kingdom
    Cazual Haze's Tools
    Thanks nice idea my lathe would struggle to get that sort of finish I just dont think its rigid enough.
  11. #8
    PayPal transfer or Amazon.com gift card?
    Download plans for tool posts.
