Results 1 to 10 of 22
Thread: How to re-align tailstock?
  1. #5
    Sep 2015
    Kansas
    The button method. This is one of the easiest ways to do it. Once the buttons are made, put the small end of one in a collet or 4 jaw chuck, make sure it's running true. Put the other one on a center in the tailstock and bring the 2 big ends together. Measure across them horizontally with a mike as you adjust the tailstock side to side. When the reading across both buttons is the nominal diameter of the button, the tailstock is centered.
  2. The Following User Says Thank You to Toolguy For This Useful Post:
    rendoman (May 6, 2017)
