Results 1 to 10 of 14
Thread: Innovative Router lift mechanism
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Hi !
    This is a new kind of Router lift mechanism.
    We've seen so many things on that topic, sometimes very complicated contraptions, with screws, slides, or sometimes gears.
    They often have several drawbacks, like heavy footprint, limited access to the chuck, intrusive, see destructive for the router, etc ...
    Sometimes, the pulling action applies only to one of the router posts, which works well at the beginning, with plenty of WD40, but stops working after some hours because of wood dust.
    This mechanism fixes all of these drawbacks.
    And it is very simple, I took maybe half a day to make it.
    It's based on ... bicycle break cables !
    And it is really powerful, I can prove it, in my case, it lifts like a charm a router "beast" made for carpenters, German made, which weights maybe 15kg !
    Here it is on my site : https://www.labellenote.fr/articles....=313&tconfig=0
    And on Youtube :
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 16 Users Say Thank You to Christophe Mineau For This Useful Post:
    baja (Jul 25, 2020), brianp (Jul 22, 2020), bruce.desertrat (Jul 21, 2020), Crusty (Jul 21, 2020), DIYer (Jul 23, 2020), Drew1966 (Jul 26, 2020), emu roo (Dec 12, 2024), fizzloid (Mar 3, 2023), IAMSatisfied (Jul 21, 2020), Jon (Jul 21, 2020), Kevic (Jul 21, 2020), Metallurg33 (Jul 26, 2020), Saltfever (Jul 22, 2020), Sleykin (Jul 21, 2020), threesixesinarow (Jul 22, 2020), Tonyg (Jul 25, 2020)
    bruce.desertrat's Tools
    Very slick, but my mind is still boggling at a 15KG router!! what a beast!
  4. The Following User Says Thank You to bruce.desertrat For This Useful Post:
    Christophe Mineau (Jul 22, 2020)
    Dry Gulch, Tx
    Crusty's Tools
    Great idea, and no servos, Arduinos, stepper motors, lead screws, etc. were required to make a fully functional device.
    I didn't see any breaks in the brake cables though.
  6. The Following User Says Thank You to Crusty For This Useful Post:
    Jul 2014
    France, Brittany !
    Yes, it's a possible future evolution.
    On this router, the break is one of the handle, you just have to rotate it, and it's accessible through a door on the cabinet under the table.
    An evolution would be to command that handle using a cable either.
    Cheers !
    Christophe
    Dry Gulch, Tx
    Crusty's Tools
    I understand English isn't your first language so just a gentle correction. Brake is what the cables did on the bicycle, break is destructive action.
    I think I would make the lift crank wheel a little smaller in diameter to that it doesn't extend above the table surface - you just never know what size and shape the next workpiece may be and you might need it to extend past the edge where the crank is.
  9. The Following User Says Thank You to Crusty For This Useful Post:
  10. #6
    Jul 2014
    France, Brittany !
    Oh yes ! sorry for that mistake , and thanks for telling me.
    Unfortunately, I cannot edit and fix my message, (maybe Jon could help ?)
    Brake
    Sure, actually, the beauty of this thing is that you can choose where you locate the mechanism on the machine, and here, I screwed it under the table only for the sake of demonstration. In fact I was in a hurry to deliver it to my friend, so he will have to take care of it.
    I think it would be better located on the side wall.
    Other option would be to make a removable crank, but here I had no time for that.
    Cheers !
    Christophe
  11. #7
    Dry Gulch, Tx
    Crusty's Tools
    A simple wheel trim to reduce its diameter a bit so that the wheel doesn't extend above the table surface would do it, in keeping with your KISS method (Keep It Simple, Stupid - a common phrase for design guidance in the US).
    This brings to mind one of my favorite problem solver devices. On big trucks and other machinery there is commonly a power takeoff control, which consists of a rubber coated long spring guide through which a solid but flexible metal wire travels with a knob at one one, used to operate machinery controls. Since it can deliver a significant amount of force by pushing or pulling on the knob and the guide is small and flexible enough to reach into many difficult to access locations often times it's a great, cheap solution for difficult controls. Some even come with a hand tightened friction nut to lock the wire at any position within its travel range.
    Here's one I found at Amazon that's only $7.
  12. The Following User Says Thank You to Crusty For This Useful Post:
  13. #8
    Thanks Christophe Mineau! We've added your Router Lift to our Router Tables category,
    as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
  14. #9
    Quote Originally Posted by bruce.desertrat View Post
    Pretty slick. I have an old Bosch that is almost that big. Definitely a two hander. You only start it with one hand control once.
  15. The Following User Says Thank You to ibdennyak For This Useful Post:
    Christophe Mineau (Jul 24, 2020)
  16. #10
    Congratulations Christophe Mineau - your Router Lift is the Homemade Tool of the Week!
    This is a difficult prize to win with something as simple as a router lift; it's only been done once before with revwarguy's Arduino-controlled lift. However, this is a clever and unique approach.
    Magnetic Welding Ground by orioncons36
    Electric Shears by meanwhileinthegarage
    Vise Hold Down by craig9
    Magnetizer by diyfixman
    Panel Plane by Philip Davies
    Tangential Tool Holder by celsoari
    Dowel Jig by Mazay
    Center Square by machining 4 all
    Mini Grill by orioncons36
    Scribe by engineer steve
    Temporary Bench Shelf by mklotz
    Vise by fawabros
    Table Saw Bowl Shaping Method by Christofix
    Anvil Stand by bobneumann
    Optical Center Punch by MachineNZ
    Lathe Motor Protective Box by machining 4 all
    Mill Clamping Nuts by Carnel
    Shop Stool by bouboulas
    Christophe Mineau - you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    This is your 11th Homemade Tool of the Week win. Here are all of your Homemade Tool of the Week winning tools. Congrats again
  17. The Following User Says Thank You to Jon For This Useful Post:
