Results 1 to 10 of 11
Thread: Keyway Cutter
    Jan 2016
    Dubrovnik - Croatia
    LMMasterMariner's Tools
    Keyway Cutter
    Made keyway cutter which I needed to cut keyways in 14 gears and 2 pulleys for my present project (external lathe headstock gearbox - still in progress, but I can see the end).
    Made from 16 mm dia stainless steel round bar. Very simple to make but some elbow grease was used when filling the square hole for 6 x 6 mm square HSS bit. It can be used in lathe and drill.
    Cheers
    LMMasterMariner
    Attached Thumbnails Attached Thumbnails Keyway Cutter-01.jpg   Keyway Cutter-02.jpg   Keyway Cutter-03.jpg   Keyway Cutter-04.jpg   Keyway Cutter-05.jpg
    Keyway Cutter-06.jpg   Keyway Cutter-07.jpg   Keyway Cutter-08.jpg   Keyway Cutter-09.jpg   Keyway Cutter-10.jpg
    Keyway Cutter-11.jpg   Keyway Cutter-12.jpg   Keyway Cutter-13.jpg   Keyway Cutter-14.jpg   Keyway Cutter-15.jpg
    Keyway Cutter-16.jpg   Keyway Cutter-17.jpg   Keyway Cutter-18.jpg   Keyway Cutter-19.jpg
  2. The Following 23 Users Say Thank You to LMMasterMariner For This Useful Post:
    aphilipmarcou (Mar 12, 2018), Canobi (Mar 12, 2018), Captainleeward (Mar 12, 2018), clydeman (May 28, 2020), darkoford (Mar 16, 2018), emu roo (Jun 17, 2025), Home-PC (May 29, 2020), jjr2001 (Mar 13, 2018), Jon (Mar 12, 2018), JRock (Mar 12, 2018), Metallurg33 (Mar 16, 2018), mwmkravchenko (Mar 12, 2018), NickP (Mar 14, 2018), Okapi (May 29, 2020), Paul Jones (Mar 12, 2018), philipUsesWood&Brass (Jul 12, 2018), PJs (Mar 13, 2018), redearthbonsai (Jul 12, 2018), rossbotics (Mar 12, 2018), Seedtick (Mar 12, 2018), Toolmaker51 (Mar 13, 2018), VegeKev (Mar 13, 2018), yves78 (Mar 13, 2018)
    Dec 2013
    Florida
    rossbotics's Tools
    Looks great, cant' wait to see the finished product
    Comments are always welcome
    Doug
  4. The Following User Says Thank You to rossbotics For This Useful Post:
    LMMasterMariner (Mar 18, 2018)
    May 2014
    Del Mar, California
    Paul Jones's Tools
    LM Master Mariner,
    That is lot of special work steps and the finished broaches look very precise. I like the way you created the special rings for protecting the gear teeth during the boring and broaching operation.
    Looking forward to seeing the lathe headstock gearbox when it is finished.
    Thank you for the posting.
    Regards,
    Paul Jones
  6. The Following 2 Users Say Thank You to Paul Jones For This Useful Post:
    LMMasterMariner (Mar 18, 2018), PJs (Mar 13, 2018)
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Hello, LMMasterMariner , nice piece of work there my friend...Cap. I was just getting ready to make one you beat me to the punch
    ha ha..
  8. The Following 3 Users Say Thank You to Captainleeward For This Useful Post:
    LMMasterMariner (Mar 18, 2018), Paul Jones (Mar 12, 2018), PJs (Mar 13, 2018)
    Jan 2018
    petertha's Tools
    So in the lathe environment, do you set the tool, traverse across the keyway shaving a bit off, retract the tool using cross slide, rinse & repeat until final depth? If so, about how much per slice?
  10. The Following User Says Thank You to petertha For This Useful Post:
    Tuomas (Mar 16, 2018)
  11. #6
    Supporting Member aphilipmarcou's Avatar
    Dec 2016
    new zealand
    aphilipmarcou's Tools
    Thanks for that- lots to observe there with good pictures too.. I like your brake caliper on the lathe!
  12. The Following User Says Thank You to aphilipmarcou For This Useful Post:
    Paul Jones (Mar 13, 2018)
  13. #7
    Jan 2016
    Dubrovnik - Croatia
    Quote Originally Posted by petertha View Post
    I was broaching keyways by moving the carriage (elbow grease again) back and forth and for the first cuts where I already had the hole, I could increase 0.06 mm for each pass and near the end I was able to increase 0.01 mm per pass. Also from time to time made several passes without increments due to elasticity of gear material. It took me about 5 minutes to make keyway in a gear (#45 steel, thickness 15 mm, hole I.D. 20mm, key 6 x 6 mm; little bit more than 3 mm in gear keyway)
    Cheers
    LMMasterMariner
  14. The Following 4 Users Say Thank You to LMMasterMariner For This Useful Post:
    NickP (Mar 14, 2018), Paul Jones (Mar 13, 2018), PJs (Mar 13, 2018), Tuomas (Mar 16, 2018)
  15. #8
    Thanks LMMasterMariner! We've added your Keyway Cutter to our Machining category,
    as well as to your builder page: LMMasterMariner's Homemade Tools. Your receipt:
  16. The Following User Says Thank You to DIYer For This Useful Post:
    LMMasterMariner (Mar 14, 2018)
  17. #9
    Congratulations LMMasterMariner - your Keyway Cutter is the Homemade Tool of the Week!
    Large week, with many excellent builds, but this one really stood out. Some other nice picks from this week:
    Hydraulic Metal Bender by Vyacheslav.Nevolya
    Edge Clamps by thehomeengineer
    Shaft and Hole Fitment Program by mklotz
    Long Reach Scribe by baskarz
    Slitting Saw Arbor by Canobi
    Planer Table Mount by Tuomas
    Cutting Torch Bevel Mount by oldtimer
    Spray Can Puncturing Tool by Texf1
    Lathe Bed Stop Handle by thehomeengineer
    Square by Toolmaker51
    Drill Extension by olderdan
    Knurling Tool by editor@glue-it.com
    Lathe Tool Height Gauge by Rorschach
    Boring Bar Rack by Paul Jones
    Marking Knife by Rorschach
    File Handle by Captainleeward
    Machete by Turboconqueringmegaeagle
    Dump Truck Rebuild by Frank S
    Load Spreader Bar by xynudu
    Roller Handwheel by thehomeengineer
    Dividing Head Refurbishing by thehomeengineer
    Angle Grinder Box by Workshopshed
    LMMasterMariner - you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    This is your 4th Homemade Tool of the Week win. One more win, and you'll join these other 5-Time Homemade Tool of the Week winners: rossbotics, Christophe Mineau, Brendon, mklotz, Vyacheslav.Nevolya, brianhw, Tuomas, olderdan, tonyfoale.
    Here are all of your Homemade Tool of the Week winning tools:
  18. The Following 4 Users Say Thank You to Jon For This Useful Post:
    LMMasterMariner (Mar 16, 2018), PJs (Jul 15, 2018), rossbotics (Mar 18, 2018), Tuomas (Mar 16, 2018)
  19. #10
    Dec 2013
    Florida
    rossbotics's Tools
    Congratulations on your win, well deserved
    Doug
  20. The Following 2 Users Say Thank You to rossbotics For This Useful Post:
    HobieDave (Apr 5, 2020), LMMasterMariner (Mar 18, 2018)
