Leatherman Bi-Metal Saw Blade Accessory
The stock Leatherman Wave with three blades can handle most reasonable cutting tasks, but what about cutting bolts, copper pipe, and pvc? In just a few minutes I adapted an 18tpi bi-metal blade to fit the multitool. I chose this type of blade over a hacksaw blade for rigidity. Pressure helps the cutting speed so I made it mount differently, without using the bit holder. With this setup you can apply enough pressure and have the leverage to cut so many more materials at a reasonable speed. The length of the blade was shortened so it slips into the factory Leatherman sheath. I use it on my Leatherman Wave, but the design can work on other models and even other brands of multitools.
https://youtu.be/Lu2QKNx9tEY
