Results 1 to 10 of 10
Thread: Machinist Vise and Milling/Drilling Vise Stops
  1. #4
    In my book the best vise stops do not attach onto jaw itself...but into body of the non-moving side, just as jjr2001 describes.
    I'll offer an easy work-around of slotting this variety of clamp.
    a] Lightly sand or surface grind two plates of desired clamp size, a good proportion is width 3-5 times the rod diameter, with the pair twice rod diameter in thickness.
    b] Drill and tap one side, clearance drill the other, this will provide clamping action via a screw. 1/4-20 or 28 is satisfactory.
    c] Clamp both face to face in machine vise, with 2 thicknesses of paper in between.
    e] Edge find for the middle, distance from end and spacing hole to hole. I like offsetting holes from center to make re-orientation easy.
    f] Center, pilot, and drill [or ream] to size.
    Bingo!
  2. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    jjr2001 (Jun 11, 2018), tooly (Aug 12, 2022)
