Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: Magnetising and demagnetising tools.
    Quote Originally Posted by cales2021 View Post
    I found Tony's post only recently and it struck me that the easiest construction method would be with a 3D print. For people with a printer you can download a Fusion file and a STEP file from my blog.https://www.altrish.co.uk/2022/02/19...ymium-magnets/. The demagnetiser works a treat.
    The easiest construction method varies with the facilities and materials that any given constructor has available. 3D printing would be about the hardest method for me.
  2. #12
    Since making the original post I made a standalone device using the original rotor. I fitted it to a scrap washing machine pump motor, added a switch and encased most of it in a plastic junction box. It sits permanently on the end of a bench ready for immediate use, eliminating the inevitable search for the mislaid rotor and then fitting to a drill. The extra convenience means that it gets used quite regularly rather than continuing to work with a magnetised tool.
    Magnetising and demagnetising tools.-demag-11.jpg Magnetising and demagnetising tools.-demag-12.jpg Click for full size.
    I just have to remove the keeper, switch on and it is ready to go.
    Magnetising and demagnetising tools.-demag-13.jpg Magnetising and demagnetising tools.-demag-14.jpg
    A couple of typical thingies to demagnetise.
    BTW. The keeper is there to prevent the magnets attracting magnetic junk when not in use. That is 100% effective.
  3. The Following 5 Users Say Thank You to tonyfoale For This Useful Post:
    baja (Jun 1, 2022), h7eh7e (Jun 2, 2022), Jon (May 30, 2022), mwmkravchenko (Jun 1, 2022), Paul Jones (Jun 4, 2022)
  4. #13
    Thanks tonyfoale! We've added your Demagnetizer to our Miscellaneous category,
  5. #14
    2025 Update.
    The motor driven demagnetiser is still where it was and it is used almost every day at least once, often multiple times. It is one of those tools that everyone should have as a first birthday present.
    How do vernier calipers get magnetised? I have yet to figure that out.
  6. The Following User Says Thank You to tonyfoale For This Useful Post:
    Saltfever (Jul 16, 2025)
