Results 1 to 7 of 7
Thread: Making Chain Drive Differential
  2. The Following 10 Users Say Thank You to warsztatOdZera For This Useful Post:
    albertq (Mar 14, 2026), Bullet500 (Sep 19, 2022), Frank S (Sep 19, 2022), hemmjo (Sep 20, 2022), johncg (Sep 20, 2022), Jon (Sep 19, 2022), odd one (Sep 19, 2022), rdarrylb (Sep 20, 2022), rebuilder1954 (Sep 24, 2022), schuylergrace (Sep 19, 2022)
    Thanks warsztatOdZera! We've added your Chain Drive Differential to our Automotive category,
    as well as to your builder page: warsztatOdZera's Homemade Tools. Your receipt:
    Lake Tahoe
    IntheGroove's Tools
    How do you fill and check the lube level...
    It would appear he is going to rely on hard grease for lubrication. This would be fine for the type of unit he made as every thin is almost in the same constant rotation only differing when making turns causing 1 wheel to over run or under run the other.
    I would be more concerned with adding the snap ring retainers to secure the axles to the spider gears. This can be accomplished on at least 1 of the axles during assembly, The other side shouldn't be a problem either since there is room behind the pillow block bearing.
    All in all it is a great idea
    Congratulations warsztatOdZera - your Chain Drive Differential is the Homemade Tool of the Week!
    This is very nicely made, and it will be interesting to see what it ends up in.
    Micrometer Anvil by Occasional machinist
    Machinist's Hammer by AB-SHOP
    Sandblasting Gun by PowerMk
    Downdraft Sanding Box by e_m_maker
    Briquettes by Mr.DK DIY
    Mill Table Stops by mr_modify1
    3D Printed Cable Sheath Stripper by Carnel
    warsztatOdZera - you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    This is your 8th Homemade Tool of the Week win. Here are all of your Homemade Tool of the Week winning tools. Congrats again
    Isambard's Avatar
    Aug 2019
    Hawke's Bay, New Zealand
    Last century, used to make chain drive diffs out of BMC FWD diffs. Didn't bother making new carriers, just made a Al cylindrical cover to fit carrier, see 51 seconds.
    Machined carrier for o ring grooves for sealing... Sprocket bolted on instead of ring gear.
  8. #7
    Isambard's Avatar
    Aug 2019
    Wire snap rings are standard automotive practice for inner axle retaining... They will disengage with the use of a sliding hammer...
    I do consider that he is a trifle optimistic on the lube side, however, considering he fitted oil seals.
