Results 1 to 4 of 4
Thread: Making precisely-sized countersunk washers using a glue chuck
    neilg4dbn's Avatar
    Aug 2021
    Yorkshire, UK
    neilg4dbn's Tools
    I needed to make retention washers to prevent the jaws of the tube spider mandrel from falling off. Short video about making the washers and machining then to a precise thickness using superglue and a propane torch on the remaining stock in the chuck.
  2. The Following 12 Users Say Thank You to neilg4dbn For This Useful Post:
    butlerandrew (Feb 12, 2025), chainsawd (Jan 10, 2022), ducksface (Jan 13, 2022), emu roo (Oct 10, 2025), johncg (Jan 10, 2022), Jon (Jan 6, 2022), lassab999 (Jan 5, 2022), Little Rabbit (Jan 6, 2022), mtsintra (Feb 12, 2025), Ralphxyz (Jan 9, 2022), Toolmaker51 (Feb 6, 2022), WmRMeyers (Jan 7, 2022)
    Thanks neilg4dbn! We've added your Countersunk Washers to our Fastening category,
    as well as to your builder page: neilg4dbn's Homemade Tools. Your receipt:
    Apr 2012
    NorCal
    Saltfever's Tools
    Deleted. . .
  6. The Following User Says Thank You to Saltfever For This Useful Post:
    neilg4dbn's Avatar
    Aug 2021
    Yorkshire, UK
    neilg4dbn's Tools
    Someone asked why I couldn't cut the countersink before parting off. In theory that is feasible if the parting tool makes a really good finish at a precise position, but the 2mm parting blades tend to leave some machining marks and don't always go in perfectly straight, so it's way easier to use the glue chuck. There is a variable that needs to be considered. The thickness of the glue line will affect the finished thickness. I tried to get that consistent by using the same amount of finger pressure and glue. Sorry if I didn't make it clear enough in the clip. Thanks for the question.
  8. The Following 2 Users Say Thank You to neilg4dbn For This Useful Post:
    cognitdiss (Dec 26, 2022), emu roo (Oct 10, 2025)
