I'm not a machinist so when I see things like this I do find them very helpful. Thank you. Mr Mikey.
Strange the V-block is at a angle to the table. I suppose if you are only drilling one hole it doesn't matter.
Ralph
Hi: Really nice way to get your V-block centered!
Here is a simple V-block I made from a 4x4 timber. Note the clamping slots across the ends:
Attachment 47764
I also made one off center for drilling bamboo flooring:
Attachment 47772
If you drill too many holes into it, just cut a new one. Good luck, Carl.
Thanks carl blum! We've added your Woodworking V-Block to our Woodworking category,
as well as to your builder page: carl blum's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-woodworking-v-block"> <img src="/uploads/270048/homemade-woodworking-v-block.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-woodworking-v-block">Woodworking V-Block</a> <span> by <a href="https://www.homemadetools.net/builder/carl+blum">carl blum</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/v-block'>V-block</a> </div> </div> </div> </div>
