Results 1 to 10 of 12
Thread: Milling Work Stop
    Supporting Member Catfish's Avatar
    Oct 2013
    Mariposa, California
    Catfish's Tools
    Milling Work Stop
    The work stop was inspired by Tom Lipton of Oxtools. I made two of these for about $70.00, one for my son and myself for Christmas. This style of work stop is great, the best I have ever used.
    Milling Work Stop-image.jpgMilling Work Stop-image.jpgMilling Work Stop-image.jpgMilling Work Stop-image.jpgMilling Work Stop-image.jpgMilling Work Stop-image.jpgMilling Work Stop-image.jpgMilling Work Stop-image.jpgMilling Work Stop-image.jpg
    I have many more photos.
  2. The Following 5 Users Say Thank You to Catfish For This Useful Post:
    Home-PC (Dec 12, 2021), Jon (Aug 29, 2015), kbalch (Jan 8, 2014), LMMasterMariner (Jan 8, 2018), Paul Jones (Aug 29, 2015)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Great work! An attractive and useful piece. What material was used?
    Ken
    Oct 2013
    Catfish's Tools
    I used 6061 alu, Stainless -Pins, top stud, position rod, 1018 steel for 'T' nuts, Steel socket head cap screws.
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks! I thought it looked like 6061, but didn't want to make assumptions... :-)
    I'll get it added to the database shortly.
    Ken
  6. The Following User Says Thank You to kbalch For This Useful Post:
    Catfish (Jan 9, 2014)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Catfish! I've added your Milling Work Stop to our Machining category, as well as to your builder page: Catfish's Homemade Tools. Your receipt:
    Jun 2012
    Harvey Melvin Richards's Tools
    Nice stop.
  9. The Following User Says Thank You to Harvey Melvin Richards For This Useful Post:
  10. #7
    Look like a very versatile design. Very well made, as usual.
  11. The Following User Says Thank You to DIYer For This Useful Post:
    Catfish (Jan 10, 2014)
  12. #8
    May 2013
    steamingbill's Tools
    Hello,
    I'm a Milling Newbie - what do you do with this thing ? Why is it a useful tool ? Does it define a repeatable reference point in 3d space that you line things up against to make 20 identical widgets ?
  13. #9
    Oct 2013
    Catfish's Tools
    Steamingbill, Yes to all. Also if you need to remove your one off widget you can then replace it in the same location.
    Thanks, Randy
  14. The Following User Says Thank You to Catfish For This Useful Post:
    Jon (Aug 29, 2015)
  15. #10
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Randy,
    Beautiful to look at and very useful. I like your technique for milling the curved surfaces by hand rotating the part between the two stops. I have several projects than can use this method. What depth of cut did you use for each rotation around the threaded rod until you arrived at the final depth?
    Regards, Paul
