Results 11 to 20 of 24
Thread: Mini Lathe Cross Slide Bearing Modification & Travel Extension
    Dec 2017
    Cape Coral, FL
    old_toolmaker's Tools
    The cross slide of my 7 x 16 mini lathe never had a nice smooth feel to it since I removed it from the box. I designed this new bolt on cross feed assembly to solve several issues. Some of the new features are: (1) added a ball thrust bearing. (2) Added 3/4" cross slide travel toward the operator with no need to machine out clearance in the saddle casting. (3) New longer, tighter tolerance cross feed screw (4) New bronze 3/8-20 L.H. nut with integral dowel and oil port. (5) New slip ring micrometer dial. (6) Backlash can be adjusted and maintained at less than .002". (7) New hand wheel which is extended out toward the operator to minimize interference with the carriage hand wheel. (8) Hand scraped cross slide mating surfaces improving parallelism and squareness to the lath axis. It has made a dramatic improvement to the lathe. My next project is to do a similar improvement to the compound slide. The picture below shows the comparison of the original screw assembly to the new version.
Name:	Cross Feed ScrewAssy Stock vs New Mod.jpg
Name:	Cross Feed ScrewAssy W.jpg
Name:	Cross Feed ScrewAssy C.jpg
Name:	Cross Feed ScrewAssy B.jpg
Name:	Cross Feed ScrewAssy Y.jpg
Name:	Cross Feed ScrewAssy Z.jpg
Name:	Cross Feed ScrewAssy D.jpg
Name:	Cross Feed ScrewAssy Stock vs New Mod A.jpg
ID:	25950   Click image for larger version.
Name:	Cross Feed ScrewAssy Stock vs New Mod B.jpg
    Dick
    Links to some of my plans:
  2. The Following 25 Users Say Thank You to old_toolmaker For This Useful Post:
    black joke19 (Aug 11, 2021), boilerman (Jan 21, 2021), DIYSwede (Jun 5, 2019), emu roo (Dec 9, 2024), high-side (Oct 6, 2018), Home-PC (Feb 22, 2020), jjr2001 (Oct 5, 2018), Jon (Oct 5, 2018), LMMasterMariner (Dec 25, 2018), marksbug (Oct 6, 2018), MountainMan (Oct 6, 2018), mr mikey (Apr 10, 2024), mwmkravchenko (Apr 10, 2024), Okapi (Oct 25, 2018), olderdan (Oct 5, 2018), Paul Jones (Oct 17, 2018), Ralphxyz (Apr 10, 2024), rossbotics (Oct 6, 2018), Seedtick (Oct 5, 2018), threesixesinarow (Oct 5, 2018), tonyfoale (Mar 14, 2019), TSiArt (Oct 10, 2018), UncleBob (Oct 6, 2018), uv8452 (Apr 10, 2024), whitebear (Aug 10, 2024)
