Results 1 to 6 of 6
Thread: Mini Mill - DIY Milling Machine
    Supporting Member cagiva's Avatar
    Apr 2021
    cagiva's Tools
    Scratch built table top mini mill made from common materials. Simple to construct without the complications of specialised tooling being needed. It is possible to make and assemble this machine using only basic hand tools and a drilling machine.
    • 1 meter (3.2 Feet) or less of Aluminium Profile
    • A single 300x300 MM sheet of Material is sufficient for the entire build
    • The flat and square bar seen was used for convenience. The parts could arguably be derived from the same material as the machine sides
    • Tapped holes are not strictly necessary
    • Base plate is salvaged mild steel 130MMx120MMx8MM
    Took about 6 hours to put together. Quite a fun little build and the machine capabilities blew me away a bit, wasn't expecting much but am now impressed after some tests. The aluminium extrusion is 35x35 MM with 6 MM T Slots, I recon PG40x40 Heavy will work as well (10 MM T Slot).
    The sheet of clear plastic is a chip guard that slots into the table.
    Mini Mill - DIY Milling Machine-iso-view-image.pngMini Mill - DIY Milling Machine-front-view.pngMini Mill - DIY Milling Machine-side-view.png
    Three views with Rotary Tool Spindle fitted
    The Z axis is a bolt and brass nut combo. The knee is drilled about 80% through to accommodate the screw.
    Mini Mill - DIY Milling Machine-img_20241007_193940.jpgMini Mill - DIY Milling Machine-img_20241007_193826.jpgMini Mill - DIY Milling Machine-img_20241007_185744_edit_81587411391784-removebg-preview.png
    Close Up Milling Action.
    Tested climb milling, plunging and slot milling without any drama. One notable issue is the lack of machine dampening, although rigid with little to no chatter. from what I can tell, at higher spindle speeds vibrations tend to wiggle things loose.
    Mini Mill - DIY Milling Machine-screenshot_20241007_135900_com.hihonor.photos.jpgMini Mill - DIY Milling Machine-img_20241007_190423_edit_81542745923166.jpgMini Mill - DIY Milling Machine-img_20241007_190507_edit_81524518393549.jpg
    6 MM 2 Flute Carbide Cutter (Straight Flute) in cast iron plus micro milling with 3 MM HSS dovetail cutter
    Cutting parameters: 0.4 - 4 MM depth of cut. 18000-25000 RPM @ 100-200 MM/MIN full cutter width
    The threaded holes are for set screws and would be used to level the gibb and remove slop. The holes should have been drilled closer to the operator (offset from the through hole axis'). I had to use thick shims without set screws to achieve the desired results.
    Mini Mill - DIY Milling Machine-img_20241004_144819-removebg-preview-1-.pngMini Mill - DIY Milling Machine-img_20241005_095832-removebg-preview.pngMini Mill - DIY Milling Machine-img_20241005_103652-removebg-preview.pngMini Mill - DIY Milling Machine-img_20241005_120540-removebg-preview.png
    Mini Mill - DIY Milling Machine-img_20241005_115906-removebg-preview.pngMini Mill - DIY Milling Machine-img_20241005_145810-removebg-preview.pngMini Mill - DIY Milling Machine-img_20241005_153631-removebg-preview.png
    To avoid drilling into faces of the extrusion I opted to run an M5 rod through the centre and bolt the ram guide block and base plate together through the column. I tested the unit without this rod and it works just fine. Obviously the tool ends up less ridged but it didn't seem terrible.
    Mini Mill - DIY Milling Machine-img_20241005_114128-removebg-preview.pngMini Mill - DIY Milling Machine-img_20240928_142528-removebg-preview.pngMini Mill - DIY Milling Machine-img_20241004_221438-removebg-preview.pngMini Mill - DIY Milling Machine-img_20241005_142939-removebg-preview.png
    Mini Mill - DIY Milling Machine-img_20241005_164001-removebg-preview.pngMini Mill - DIY Milling Machine-img_20241005_101655-removebg-preview.pngMini Mill - DIY Milling Machine-img_20241005_152649-removebg-preview.png
    Metal-on-metal contact is avoided by using book biding cover plastic cut outs with slits cut in them to trap oil. These cut outs are sandwiched between sliding surfaces.
    This same plastic is also used as shim stock when required. I'm sure its not the best all round material but it certainly does the trick and costs pennies a sheet at any stationary shop. I may also like to try gasket paper perhaps.
    All faces of the aluminium extrusions were honed to remove burs and other surface defects.
    Mini Mill - DIY Milling Machine-img_20241005_164929-removebg-preview.pngMini Mill - DIY Milling Machine-img_20241005_164944-removebg-preview.pngMini Mill - DIY Milling Machine-img_20241005_165045-removebg-preview.pngMini Mill - DIY Milling Machine-img_20241005_165323-removebg-preview.pngMini Mill - DIY Milling Machine-img_20241005_165404-removebg-preview.png
    Low-tech table alignment. A flex shaft spindle tommy bar is colleted and the long end swept over four points on the table. First the table is made perpendicular to the spindle at the front side. The table guide block has two bolts connected to the knee. the upper bolt is the pivot point and the lower to lock it. Both bolts are torqued when the the wiper gap is equal across both points. The ram is traversed back and the distances checked as pictured to ensure parallelism with the table (if not, the machine is reassembled with special care given to making the column and ram block meet at 90 degrees) the table 'level' is then checked a second time from the back.
    Would love to hear any thoughts and suggestions thanks,
    Cheers.
    Best,
    D.S. [cagiva]
  2. The Following 9 Users Say Thank You to cagiva For This Useful Post:
    bruce.desertrat (Oct 14, 2024), DSTP (Oct 8, 2024), emu roo (Oct 8, 2024), guitwar (Nov 16, 2024), Jon (Oct 7, 2024), Ralphxyz (Oct 12, 2024), rdarrylb (Oct 8, 2024), that_other_guy (Oct 8, 2024), tuchie (Oct 12, 2024)
    Thanks cagiva! We've added your Mini Mill to our Milling category,
    as well as to your builder page: cagiva's Homemade Tools. Your receipt:
    DSTP's Tools
    This is an excellent build. Is the rigidity noticeably different between the rotary tool and the spindle? Do you happen to have any drawings or diagrams with dimensions?
    Apr 2021
    cagiva's Tools
    Thank you, glad you approve. The spindle used here is a pretty old Bosch POF 50 Router which has a touch of play in the z axis direction, the rotary tool is new out the box with practically zero play. Even so, there hasn't been a difference in rigidity when taking light cuts. When pushing both tools the rotary tool out performed the Bosch but I think that is more because of the unit being around 20 years old. (Wouldn't try anything bigger than the 370w Bosch, seems right on the money) The whole setup is far more rigid than I'd initially hoped for, really surprised me. Please see an A4 drawing Sheet attached. The drawings are of an earlier prototype but dimensions are basically identical. All metric hardware, etc.
    Attached Files Attached Files
    Best,
    D.S. [cagiva]
    Congratulations cagiva - your Mini Mill is the Homemade Tool of the Month for October 2024!
    What sets this build apart is that it can be constructed with basic tools, from common materials, in a small amount of time. For the time, money, and skill expended, this mini mill offers a very high return in increased capability.
    Some more good builds from October:
    All Terrain Ride On Mower by darus627
    Mill Vise Tramming Blocks by shednanigans
    Electronic Lathe Controller by Stevohdee
    Cam Grinding Setup by tonyfoale
    Shop Hook by hwmrob
    CNC Router Bed by Cazual Haze
    Power Steering Hose Fitting by gatz
    Large Kant Twist Clamp by celsoari
    Welding Clamp by orioncons36
    Hot Pipe Bending Fixture by Make Things
    Cross Slide Lock by shednanigans
    Flood Coolant Oil Skimmer by shednanigans
    Spring Cut Off Tool by The Hobby Machinist NZ
    Fishhook Dehooker by mklotz
    Collet Chuck for Hex Head Bolts by Alans Home Workshop
    Lathe Tool Holder by shednanigans
    Lawn Tractor by warsztatOdZera
    Mini Digger Ripper Tooth by thehomeengineer
    Axial Coupler by rgsparber
    Radiator Brush by Rorschach
    Mini Digger Rake by thehomeengineer
    Ball Turner by mariost
    Supplied Air Leak Tester by Alans Home Workshop
    Router Fence by Make Things
    cagiva - You'll be receiving a $250 cash prize, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and prize choice and I'll get it sent over right away.
    You've also been granted lifetime Supporting Member status, so you'll never have to pay for membership again.
    And, you'll now notice the four-column award in the awards showcase in your postbit, visible beneath your username:
    Nice work
    Supporting Member carl blum's Avatar
    Nov 2021
    Charleston, South Carolina
    carl blum's Tools
    Very nice milling machine: It has a configuration similar to a Deckel FP1, a very rigid design, a bit like playing your cards close to your chest.
    Download plans for milling tools.
  8. The Following User Says Thank You to carl blum For This Useful Post:
    cagiva (Nov 22, 2024)
