Results 1 to 6 of 6
Thread: A miniture tap and die for steam engine pipe threads
    Oct 2012
    jgedde's Tools
    I was building a PM Research No. 7 steam engine and needed to tap and cut male and female pipe threads in 3/16-40. These taps and dies are available but are far from cheap. I was looking at over $90 for a set.
    Since a coworker needed a set for an engine he was building, I told him if he bought the drill rod, I would try my hand at making a tap and die set for both of us. He agreed that even if I wasn't successful, I would still get tpo keep the W1 drill rod he bought.
    Here are some photos with captions showing the operations:
    Setting the taper by offsetting the tailstock and verifying it:
    Turning the tapered thread for the tap:
    Cutting the threads:
    Hardening and tempering happens... Heat to cherry red, quench. Heat to pale straw, quench again...
    Cutting the flutes. That's a dremel with a diamond coated form grinding tool held in my mill vise. Notice the grinding tool is NOT located on the vertical centerline of the tap... This gives positive rake to the cutting edges. The mill spindle was indexed by eye to give 4 flutes. With the mill tunred off (and UNPLUGGED), the quill was plunged down onto the grinding wheel to cut (and sharpen) the flutes.
    I hit my four picture limit, so I will show more pics in another post...
    John
  2. The Following 12 Users Say Thank You to jgedde For This Useful Post:
    baja (Jan 16, 2020), C-Bag (Apr 9, 2016), emu roo (Oct 20, 2025), high-side (Jan 16, 2020), Home-PC (Aug 23, 2022), Jon (Oct 19, 2012), JRock (Apr 24, 2018), kbalch (Oct 19, 2012), Moby Duck (Apr 24, 2018), Paul Jones (May 4, 2015), StephenL (Dec 5, 2017), Toolmaker51 (Feb 7, 2017)
    Oct 2012
    jgedde's Tools
    Using the newly made taps to cut the threads for the die:
    A miniture tap and die for steam engine pipe threads-using-newlay-made-tap-thread-die.jpg
    Cutting the rake holes:
    Hardening of the die now occurs the same way as the tap. The rake holes are afterwards cleaned up with a cylindrical diamond cutter in the dremel to return the edges to sharpness.
    Some test threads:
    Test fit:
    John
  4. The Following 6 Users Say Thank You to jgedde For This Useful Post:
    baja (Jan 16, 2020), emu roo (Oct 20, 2025), Home-PC (Aug 23, 2022), Paul Jones (May 4, 2015), PJs (Apr 10, 2016), Toolmaker51 (Feb 7, 2017)
    Oct 2012
    jgedde's Tools
    Finished tap and die:
    A miniture tap and die for steam engine pipe threads-finished-tap-die-set.jpg
    That's it! You can make straight taps the same way (but without the taper)
    John
  6. The Following 5 Users Say Thank You to jgedde For This Useful Post:
    baja (Jan 16, 2020), bigtrev8xl (Apr 25, 2018), emu roo (Oct 20, 2025), Home-PC (Aug 23, 2022), PJs (Apr 10, 2016)
    Thanks jgedde! This one has been added to our Drilling and Tapping and Metalworking categories, and to your homemade tools page: jgedde's Homemade Tools. Your receipt:
  8. The Following 2 Users Say Thank You to Jon For This Useful Post:
    emu roo (Oct 20, 2025), ncollar (Apr 9, 2016)
    Oct 2012
    very nice and well documented
  10. The Following User Says Thank You to ncollar For This Useful Post:
  11. #6
    Sep 2017
    Quote Originally Posted by jgedde View Post
Name:	Verifying the taper.jpg
Name:	finished thread.jpg
Name:	Cutting the flutes.jpg
    John
    What material did you make the tap and die set from?
  12. The Following User Says Thank You to rekdr For This Useful Post:
