Results 1 to 4 of 4
Thread: Oil funnel holder
    Jul 2018
    Flora, MS
    Floradawg's Tools
    Oil funnel holder
    I recently changed the oil in my wife's car for the first time since we bought it. I set the funnel in the fill hole, and it stayed there slightly back and to the right. I figured it would stay there. It did until the funnel was about half full. Then it tipped forward and spilled oil on the engine which resulted in a rant of nasty language.
    I made these two holders. One for her car and one for my truck. Really easy to make. I used steel because I have plenty and also the weight might make it more stable. Aluminum would also work okay. Turn the smaller diameter a little smaller than the fill hole. The larger diameter large enough to form a step. For my Harbor Freight funnel a 5/8" hole was just right for the fill hole. I drilled some small holes around the 5/8" hole to let the air flow out as the oil is poured in. They let the oil flow at a reasonable rate, but I may put in four more holes to speed it up.
ID:	49261Click image for larger version.
ID:	49262Click image for larger version.
ID:	49263Click image for larger version.
ID:	49264Click image for larger version.
  2. The Following 11 Users Say Thank You to Floradawg For This Useful Post:
    albertq (May 19, 2025), baja (May 23, 2025), BuffaloJohn (May 15, 2025), DIYer (May 15, 2025), ductape (May 14, 2025), emu roo (May 15, 2025), Jon (May 14, 2025), lassab999 (May 16, 2025), nova_robotics (May 15, 2025), RetiredFAE (May 15, 2025), rlm98253 (May 16, 2025)
