Results 1 to 7 of 7
Thread: Perfect & Easy Make Dado & Rabbet Joint - KERFMAKER
    Supporting Member Didpoolhall's Avatar
    Feb 2019
    indonesia
    Didpoolhall's Tools
    Simple easy-to-make table saw jig that will let you cut perfect dados and rabbet with only the use of a single table saw blade. I had some leftover pieces from my last project. So I decided to make something out of it. This woodworking jig is made from scrap plywood and a few bits of hardware found in almost every workshop. Once set the Kerfmaker right, it works perfectly every time. Easy and repeated make dado slot & rabbet Joint
  2. The Following 4 Users Say Thank You to Didpoolhall For This Useful Post:
    dheiser4 (Dec 31, 2020), Jon (Dec 30, 2020), lasten (Jan 2, 2021), sacco1 (Dec 30, 2020)
