Again the heat is driving me off the boat so time to make a bracket to fit the radio. the radio was previously surface mounted, but I would not like to cut a hole in the new center console untill such time I have confirmed the radio works. Also technology has moved on and now it is possible to connect your radio to your GPS and if you send out a distress call your GPS coordinates are also sent, so perhaps time for an upgrade
I have seen these little simple tools, just a nice big "V" in a solid block of steel. Once the plate brkt about 1 to 1.2mm sheet steel is bent, you simply take a chisel and create a dent into the "V" right on the corner of the bracket. It gives it a lot of stiffens.
