Results 1 to 10 of 10
Thread: Plate Brkt reinforcment
    Jul 2017
    Port Elizabet, SA
    garage nut's Tools
    Again the heat is driving me off the boat so time to make a bracket to fit the radio. the radio was previously surface mounted, but I would not like to cut a hole in the new center console untill such time I have confirmed the radio works. Also technology has moved on and now it is possible to connect your radio to your GPS and if you send out a distress call your GPS coordinates are also sent, so perhaps time for an upgrade
    I have seen these little simple tools, just a nice big "V" in a solid block of steel. Once the plate brkt about 1 to 1.2mm sheet steel is bent, you simply take a chisel and create a dent into the "V" right on the corner of the bracket. It gives it a lot of stiffens.
  2. The Following 32 Users Say Thank You to garage nut For This Useful Post:
    57_210 (Apr 4, 2021), Andyt (Jan 3, 2019), baja (Jan 3, 2019), bukwessul (Jan 2, 2019), carloski (Jun 9, 2022), ChasT (Jun 9, 2022), emu roo (Oct 7, 2020), Glueman2 (Aug 1, 2022), high-side (Jan 3, 2019), JD62 (Jan 7, 2018), Jon (Oct 7, 2020), katy (Oct 8, 2020), Ken Koch (Jan 2, 2019), lassab999 (Jun 11, 2022), Miloslav (Jun 9, 2022), Moby Duck (Jan 7, 2018), mwmkravchenko (Jan 10, 2018), natie123 (Jun 3, 2018), NortonDommi (Jan 8, 2018), oldcaptainrusty (Jan 3, 2019), olderdan (Jan 7, 2018), Philip Davies (Jul 6, 2025), raceman61 (May 19, 2018), rgsparber (May 16, 2018), rlm98253 (Jan 2, 2019), Seedtick (Jan 7, 2018), Sleykin (Sep 20, 2018), sossol (Jan 2, 2019), toma (Jan 8, 2018), Toolmaker51 (Jan 7, 2018), trevor_60_r (Dec 29, 2020), volodar (Sep 20, 2018)
