Results 1 to 10 of 11
Thread: Portable Bandsaw Base
  1. #8
    Dry Gulch, Tx
    Crusty's Tools
    I'm even more pleased with it after using it for a while and so I decided to go back and fix a couple of shortcuts that I took when I fabricated it.
    I've since bored out the pivot holes and installed bronze bushings on the pivot shaft so that It won't be worn by repeated use. Then I got my angle grinder after some 1" plate, cut out a 15# chunk and made a clamp and now it has a sliding blade weight clamped onto the arm and it goes through steel just as quick as it's able. I also added another small stiffener to the upright which has ended all blade wander in the cut.
    This is a really useful tool which has sped my operation up considerably and I didn't have to spend $700 to get it.
  2. The Following User Says Thank You to Crusty For This Useful Post:
    jimmymac (Aug 10, 2024)
