Results 1 to 4 of 4
Thread: Power Hacksaw Power Hacksaw from myhobbystore.uk plansWE54 - WE54
    Jul 2014
    Madeit's Tools
    Made my Power Hacksaw from plans obtained from myhobbystore.uk.
    However I made substantial changes. Original plans were for a standard 12" hacksaw blade. the plans also called for some milling work (gear cutting) which was not available to me. I bought gears from RDG CO UK and aluminium pulleys
    The changes I made were the following:
    Made frame with 1" square tubing to suit 14' industrial hacksaw blade
    Fitted limit switch to stop saw when cut finished.
    Mounted stop start on contractor on saw.
    Fitted a lubrication system to saw i.e. grease nipples and oil cups.
    Location pin to hold saw arm in up position to safely access vice.
    Made own version of vice. (Not quite 4" capacity)
    Made bench fitted with castors for mobility.
    In hindsight I should have made throat of saw frame deeper, but not going to change it.
    Power Hacksaw   Power Hacksaw  from myhobbystore.uk plansWE54 - WE54-dscn0106.jpg[Power Hacksaw   Power Hacksaw  from myhobbystore.uk plansWE54 - WE54-dscn0109.jpgPower Hacksaw   Power Hacksaw  from myhobbystore.uk plansWE54 - WE54-dscn0108.jpg[Power Hacksaw   Power Hacksaw  from myhobbystore.uk plansWE54 - WE54-dscn0107.jpg
    Attached Thumbnails Attached Thumbnails Power Hacksaw   Power Hacksaw  from myhobbystore.uk plansWE54 - WE54-dscn0103.jpg
  2. The Following 3 Users Say Thank You to Madeit For This Useful Post:
    kbalch (Aug 7, 2014), Paul Jones (Nov 18, 2015), PJs (Nov 18, 2015)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Madeit! I've added your Power Hacksaw to our Metalworking category, as well as to your builder page: Madeit's Homemade Tools. Your receipt:
    Nov 2015
    i think i look good
    im going to make thanks
    Jul 2014
    Madeit's Tools
    Quote Originally Posted by Bady View Post
    i think i look good
    Things I would change are:
    1. Make throat of hacksaw frame deeper.
    2. Make blade stroke adjustable to use full length of blade.
    3, Make the whole vise adjustable in regard to positioning the vise along the blade stroke and I also would recommend using a power hacksaw blade as I did.
    Glad you liked it.
    Regards Madeit
  6. The Following User Says Thank You to Madeit For This Useful Post:
    Jakeapart (Mar 24, 2017)
