Results 1 to 6 of 6
Thread: Question on Wheel Hub Repair
    hemmjo's Tools
    I have a question for the combined wisdom of this group.
    One Christmas in the mid 70's I built my dad a "Little Red Wagon" 4 x 8 foot utility trailer.
    It was the very first "real" thing I ever designed and built. I was working at a "junk yard" at the time
    and also crew for their Drag Race team. I was able to use that shop to fabricate the trailer. Keeping it
    secret from my dad.
    Mid 60's Ramblers had 13" wheels and tires with front spindles and hubs that were easily bolted to
    plates welded to a square steel tube for the axle. There was no demand for them as replacement
    parts so there were plenty in the yard. The little trailer has hauled lots of stuff over 50 years since I built it.
    Recently, due to my neglect, a wheel bearing failed. The odds of finding a good, 60's Rambler hub are not good.
    I prefer to repair this one to keep it as original as possible. Plus, it is a challenge.
    On the good hub, the bearing and seal, press fit into a common bore.
    The hub that failed, rubbed against the back of the spindle and ground away the seal
    and part of the hub. There is no material remaining to hold a new seal in place.
    I centered the hub and prepared to bore the damage away to begin repair. I cleaned up
    that machined section of the hub to center it. Then checked and dialed in final center using
    the backside bearing bore
    The damage was limited to the bore affecting the seal. The bearing cup protected that part
    of the hub from damage. I was able to clean up the seal area, by boring about 0.132" oversize
    My plan is to make a steel bushing, install it then bore it to match the existing bore.
    As I prepare to make the bushing, I see two options.
    1) Do I make the bushing OD oversize then heat the hub, freeze the bushing, then press
    them together, letting them shrink and expand, to lock them together?
    IF yes, the bore is about 2 3/8", how much interference?
    OR.
    2) Do I make the bushing a little under size and JB Weld it into the bore?
    I am leaning toward the JB Weld as quick and easy.
    I appreciate any input?
  2. #2
    hemmjo's Tools
    OR... Maybe good fit with Red Loc-Tite ?
  3. #3
    Lake Tahoe
    IntheGroove's Tools
    Check out BDI Express and you might find a seal that will work...
  4. The Following User Says Thank You to IntheGroove For This Useful Post:
    emu roo (Nov 6, 2025)
    Dec 2022
    Midwest US
    ductape's Tools
    I've fixed a lot of banged-up trailer axles and hubs. A sleeve with an OD of around 0.005 less than the bore and pressed in with a finger wipe of red Loctite should last a long time.
    Search suggests a replacement seal may be a National 6917 or SKF 16659.
  6. The Following User Says Thank You to ductape For This Useful Post:
    hemmjo's Tools
    Quote Originally Posted by IntheGroove View Post
    Checked BDI they do have a seal with correct OD and ID. But the seal I need has the OD and ID in different planes. BDI showed them only in the same plane
    hemmjo's Tools
    Solution to this thread. Trailer Wheel Hub Repair
