Results 1 to 5 of 5
Thread: Quick setup jig using squares magnets and clamps
    You can never have too many framing squares. I'm sure if I were to search through every tool storage area I could dig up a dozen of them.
    Many times I will use magnets and framing squares as a set up jig. I don't always need to hold a part in place as much as I need to hold a location in space
  2. The Following 8 Users Say Thank You to Frank S For This Useful Post:
    baja (Nov 6, 2019), drivermark (Nov 10, 2019), emu roo (Mar 14, 2025), Jon (Nov 7, 2019), Scotty12 (Nov 5, 2019), Seedtick (Nov 5, 2019), shopandmath (Nov 12, 2019), Steved53 (Nov 11, 2019)
    Thanks Frank S! We've added your Setup Jig to our Metalworking category,
    Machining, welding, prototyping, even photography; a proper set-up is all about stability first, and repeatability is unquestionably next.
    Frank S's rig is classic example.
    X-Y tooling can be complicated dimensionally, but Z is where things get interesting. It is all about using the same datum for as long it is possible.
    11 Nov 2019 edit.
    Strikes me this morning, that datum phrase could better express the idea this way; It's all about preserving the datum for as long it is possible.
    I'm finishing a long awaited run of parts for myself later today. It will exhibit that concept, including mating parts that one uses the other to index accordingly. Utilizing all three Cartesian axes.
    Last edited by Toolmaker51; Nov 11, 2019 at 03:45 AM. Reason: ...not sure all that'd fit here. Lol
  5. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    Frank S (Nov 4, 2019)
    Supporting Member Steved53's Avatar
    Apr 2018
    UK
    Steved53's Tools
    I agree Frank.... I have an old 2ft x 3ft roofing square that has been very useful over the years.
    Quote Originally Posted by Steved53 View Post
    I don't know what ever happened to my old tapered framing square since I haven't seen it in many years. I used to have a square that was forged out of Bethlehem steel the back or spine was almost 5/16" thick while the inside was about 1/8" on it was the usual inscribing's for Hip, Val, riser, deg. of slope, and circle segment info on 1 side the other had rafter bracing cut angles and lengths per roof pitch angle. It was the busiest square I had ever seen with regards to the info on it.
    I don't have any idea where I got it probably in some auction and I suspect some sticky fingered worker relieved it from my kit
    Download plans for clamps.
