Results 1 to 4 of 4
Thread: Removing metal wire pipe wrapping - GIF
Hybrid View
    Removing metal wire pipe wrapping. Not really sure what the wrapping/cladding material is called. Anyone?
    Drill-powered pipe wrapper - GIF
    Internal pipe coating tool - GIF
    Culvert jet for pipe cleaning - video
    Pipe flange spreading tool - GIF
    Induction heating pipe fittings - GIF
    Scotty1 (Jun 23, 2021)
    Its called bar wrapping. This technique is employed to allow increased pressures in the piping. Often used on poly propylene, concrete, steel or stainless steel copper or just about any cylinder tubing where the pressures may exceed the normal bursting pressures. When employed the technique also affords the use of substantially thinner piping saving in material and production costs.
    Another use of the bar wrapping is in systems with a high frequency pulsation rate or infrequent extreme pressure spikes, the high tensile wrapping medium aids in reducing metal fatigue
  4. The Following 6 Users Say Thank You to Frank S For This Useful Post:
    Altair (Jun 23, 2021), hemmjo (Jun 24, 2021), Scotty1 (Jun 23, 2021), suther51 (Jun 29, 2021), that_other_guy (Jun 27, 2021), verticalmurph (Jun 24, 2021)
    Supporting Member toeless joe's Avatar
    Oct 2019
    Denver,CO
    While I would never question your vast storehouse of knowledge and experience, Frank, this time I believe you are mistaken.
    Where I grew up, it was called a 'Slinky'. Played with them for hours!
    Toeless Joe just for you
