Results 1 to 4 of 4
Thread: Removing Mill Scale
    Haslip Cycle Works's Avatar
    Haslip Cycle Works's Tools
    Removing Mill Scale
    Need to remove mill scale? I show you how to do exactly that and I even show you an option of protecting the steel once your done with it.
  2. The Following 28 Users Say Thank You to Haslip Cycle Works For This Useful Post:
    57_210 (Apr 4, 2021), albertq (Mar 30, 2024), asterix (Mar 1, 2021), baja (Mar 31, 2024), carloski (Feb 22, 2021), Chadboye (Feb 23, 2021), cohay1 (Feb 28, 2021), davidschutt (Mar 5, 2025), drivermark (Mar 1, 2021), emu roo (Feb 22, 2021), EnginePaul (Mar 9, 2021), fizzloid (Feb 23, 2021), GKK (Feb 28, 2021), hemmjo (May 26, 2025), Inner (Feb 22, 2021), Jon (Feb 24, 2021), lassab999 (Feb 22, 2021), lpresson (May 8, 2021), phred (Feb 22, 2021), rlm98253 (Feb 22, 2021), sabre-40 (Feb 23, 2021), scrubhunter (Jan 14, 2025), Skun Knuckles (Feb 23, 2021), Sleykin (Feb 25, 2021), thadrodgers (Jun 24, 2022), thehomeengineer (Mar 11, 2021), Tonyg (Feb 28, 2021), will52100 (Feb 28, 2021)
    Oct 2019
    Australia
    Like the Vinegar method , thanks
    Thanks Haslip Cycle Works! We've added your Mill Scale Removal Methods to our Metalworking category,
    as well as to your builder page: Haslip Cycle Works's Homemade Tools. Your receipt:
    May 2021
    Vancouver, Washington, USA
    Smile need to finish reply
    I like the vinegar method for several reasons.
    1. it is less costly
    2. less hazardous
    3. easier to dispose of (I dump it on the weeds out back)
    4. it works fairly well. it just takes longer is all.
    Here are some things I have found to make a difference in using vinegar
    1. For some reason, heat and light seem to make vinegar more "aggressive" on the surface of the metal, thus it seems to work a little bit better/faster if left out in the sun.
    2. vinegar is available in different levels of acidity. Regular vinegar is usually 5 percent, pickling vinegar is 6 percent, and cleaning vinegar is 30 percent acidity.
    3. vinegar will also etch/remove the zinc off of galvanized metal so it will take paint.
    WARNING!!!!!!! IF SPILLED ON YOUR CONCRETE FLOOR IT WILL EAT INTO IT VERY QUICKLY!!!!!! (don't ask how I found out that even regular 5 percent vinegar will do it to it ).
  6. The Following 3 Users Say Thank You to motorhead For This Useful Post:
    davidschutt (Mar 5, 2025), DIYer (Mar 5, 2025), emu roo (Mar 4, 2025)
