Results 1 to 10 of 11
Thread: Ring Rollers
    Iliketobuild's Avatar
    Dec 2015
    Iliketobuild's Tools
    Ring Rollers
    In the process of building a boat I ran into a problem which required the fabrication of a new tool. The rub rails for the boat are schedule 40 aluminum pipe 2 1/2" in diameter. They require significant bending along a radius of approximately 14'. I tried numerous ways to bend the pipe without a roller and wound up kinking the pipe every time. After consulting some commercial boat builders the general consensus was that a ring roller was needed. Heavy duty commercial ring rollers are extremely expensive so I decided to build one. My design utilizes 7/8" plate sides (that just happened to be the thickness I could find used). The shafts are a little less than 2" in diameter, riding on huge tapered roller bearings that are adjusted for end play using castle nuts and cotter pins. The roller shafts are driven with #80 chain and a huge gear box. I've use a VFD to control the speed and direction of the rollers. All the dies for the roller were made from a piece of 6" diameter steel repurposed from a sewage treatment plant in Michigan. The roller has worked very well, bending huge pipes without any kinking. The pipes are bent then compared to a full-size template of the radius. After the pipes are bent they are split on a band saw. Sorry for some of the pictures, the downloading software rotates them and I can't fix the problem. If anyone knows how to fix this problem let me know, I have more tools to post.
    Ring Rollers-roller-closeup.jpg Ring Rollers-bending-pipe.jpgRing Rollers-img_6411.jpg
    Last edited by Iliketobuild; Dec 15, 2015 at 06:52 AM. Reason: Can't rotate pictures
  2. The Following 5 Users Say Thank You to Iliketobuild For This Useful Post:
    Jon (Dec 15, 2015), kbalch (Dec 15, 2015), NortonDommi (Dec 11, 2018), Paul Jones (Dec 15, 2015), PJs (Dec 17, 2015)
    Thanks Iliketobuild! We've added your Ring Roller to our Ring Rollers category, as well as to your builder page: Iliketobuild's Homemade Tools. Your receipt:
    Thanks Iliketobuild! We've added your Roller Dies to our Metalworking category, as well as to your builder page: Iliketobuild's Homemade Tools. Your receipt:
    Thanks Iliketobuild! We've added your Radius Turning Tool to our Machining category, as well as to your builder page: Iliketobuild's Homemade Tools. Your receipt:
    Jul 2015
    Quote Originally Posted by Iliketobuild View Post
    I've noticed the problem and it has to do with a site's software configuration for displaying images. Sometimes the wide images are rotated (as seems to be your situation) and sometimes tall images are rotated. The simple 'solution' is to crop a copy of your pics to be sorta close to square. (I don't know how close; my experience is they don't have to be exactly or even really close to square, but you might need to experiment.) Hope you get it working, cuz I sure want to see more!
  7. The Following User Says Thank You to Leprechaun For This Useful Post:
    Paul Jones (Dec 17, 2015)
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    Admirable!
  9. #7
    Dec 2015
    Leprechaun, thanks for the tip. Will try it on the next post.
    Bob
  10. #8
    Dec 2015
    It was fun to make but took lots of precision machining to get everything to fit and work smoothly.
  11. #9
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Speaking of precision machining, I like the large-sized radius cutting tool you built for your lathe. Looks like it can handle some large parts.
  12. #10
    Dec 2015
    Yes, it works surprisingly well, made it out of some scrap material I had laying around. It is custom fit for my 13" Southbend lathe.
  13. The Following User Says Thank You to Iliketobuild For This Useful Post:
    Paul Jones (Dec 18, 2015)
