Results 1 to 6 of 6
Thread: Rotary four wheel attachment for 2"x72" belt sander/grinder
    New Lenox, IL
    garycullen's Tools
    I made a rotary 4 wheel turret for my 2" x 72" belt grinder. It uses 3",4" 6" and 8" x 2" wide wheels. Instead of 4 separate arms for each wheel it uses only ONE ARM!. It is 6-1/2" wide and the pivot is in the exact center and all 4 wheels are the same distance from the edge of the pivot arms. I set the distance for each wheel using a telescoping gauge. When you change to a different roller the belt lines up exactly. I didnt even have to adjust the tracking for any of the rollers whether on one side or pivoted to the other side. I also made the pivot on the side arms offset, so when you go from one roller to the other you don't have to adjust the arm a lot to tighten the belt.
ID:	20704gary.cullen@att.netClick image for larger version.
ID:	20705Click image for larger version.
ID:	20706Click image for larger version.
ID:	20707Click image for larger version.
ID:	20708Click image for larger version.
ID:	20709Click image for larger version.
ID:	20710Click image for larger version.
ID:	20711Click image for larger version.
ID:	20712Click image for larger version.
  2. The Following 11 Users Say Thank You to garycullen For This Useful Post:
    bvd1940 (Nov 28, 2017), CharlesWaugh (Feb 28, 2023), cwdettloff (Apr 21, 2018), emu roo (Jun 20, 2025), galebars (Nov 28, 2017), high-side (Jan 5, 2020), Jon (Nov 27, 2017), NortonDommi (Nov 28, 2017), Scotty1 (Mar 1, 2023), Seedtick (Nov 27, 2017), Toolmaker51 (Feb 28, 2023)
