Results 1 to 10 of 11
Thread: Rotation indicator + N, PE, 30 mA RCD test
  1. #9
    Supporting Member 2gsg2_muc's Avatar
    Aug 2021
    Munich
    2gsg2_muc's Tools
    Bill of Materials:
    Partlist of Outlet Tester circuit, designed for 230VAC
    Part Value Package
    ...2 FR4, 1.5mm, 35u, 2lagen, Lötstop
    ..1 2x Abstandsbolzen M3 / 18H2456 / 8 mm
    ..2 2x Schraube DIN933 M3x25 mm
    ..3 2x Stiftschraube M3x16
    ..4 7x Distanzhalter LED 20mm 18 H 518
    ..5 Recommended LED type above 2000 mcd Resistor value for R7, R8, R9, R10, R11, R12, R15
    depending on type of used LED at 10 mA. Resistor R13, R14 depending on supply voltage.
    Resistors R1 - R12 and R15 are type 0207, R13 is 0817 and R14 is 0617.
    ..6 Beschriftungsaufkleber Aufdruck aus PCB
    ..7 2x Rosette Messing 5x11
    C1, C2 1n C050-025X075
    D1 ZPD12 DO35Z10
    D2, D3, D4, 1N4004
    D5, D6, D7,
    D8, D10, D11
    LED1 gn 10 Cd LED5MM
    LED2 gn 10 cd
    LED3 gn 10 cd
    LED4 rd 10 cd
    LED5 bu 4.8 cd
    LED6 wh 10 cd
    LED7 rd 10Cd
    PE Lötpunkt P1-17
    R1, R2, R3, 10M 0207
    R4, R5, R6 3k3
    R7, R8, R9 33k
    R10, R11 120k
    R12 120k
    R13 6k8 P0817
    R14 22k 0617
    R15 120k 0207
    RCD-CURRENT TS-13P TS-13P
    RCD-TEST MS-312 MS-312
    T1 FQN1N60CTA TO92
    TOUCHSENSOR Lötpunkt P1-13
    _L Lötpunkt P1-17
    _N Lötpunkt P1-17
  2. The Following User Says Thank You to 2gsg2_muc For This Useful Post:
    mwmkravchenko (Jan 18, 2023)
