Results 1 to 10 of 10
Thread: Rough terain welder cart
    The title means just what it says
    my little Miller 210 mig welder has been suffering from a gravel floor for far too long
    very difficult to move around on the factory wheel kit
    So I dug a few items out of my classed for reuse pile of scrap and made a cart that can be moved around very easy.
    I started out with the front frame of a Toro walk behind mower
    First up modify the frame work
    Next cut the hubs out of the rear tires
    then lengthen the forks for larger tires
    he modified assembled cart frame
    I managed to make 2 hubs out of 1 so this gave me 4 hubs
    2 of these will be used on my torch cart later this week
    here I have just welded the hub into the center of a doughnut spare tire these can be bought for next to nothing but I had 2 the same size just laying around
    the finished cart may never win any beauty contests but it is very functional
  2. The Following 15 Users Say Thank You to Frank S For This Useful Post:
    baja (Jul 12, 2019), C-Bag (Sep 8, 2015), clydeman (Dec 24, 2021), DonC (Feb 20, 2016), IAMSatisfied (Dec 26, 2021), jakesnake757 (Oct 27, 2023), Jon (Sep 10, 2015), kbalch (Sep 8, 2015), mwmkravchenko (Dec 25, 2021), nevadablue (Sep 9, 2015), Paul Jones (Sep 8, 2015), pennswoodsed (Sep 9, 2015), Scotsman Hosie (Jul 13, 2019), Scotty12 (Jul 9, 2019), that_other_guy (Jul 9, 2019)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Frank S! I've added your Rough Terrain Welding Cart to our Welding Carts category, as well as to your builder page: Frank S' Homemade Tools. Your receipt:
    pennswoodsed's Avatar
    Nov 2013
    I think it's cool , beauty is function.
    One thing is for sure it rolls easy.
    Later I plan on adding a shelf on the back with some bottle supports to add one of my cutting rigs to it this way I will have both welder and torch at hand at all times. I have 2 or 3 sets of bottles gauges hoses and torches that I am not using just now anyway
    Great build. Similar concept (though slightly more complex) as some of the "off road" floor jacks we've seen, like this one by am4x4 on Pirate4x4.com:
    I'll bet she rolls like a champ. There are fewer things more frustrating than being a grown man, and forced to drag a wheeled cart over a rough surface. It makes you feel like a caveman who hasn't quite finished inventing the wheel.
  7. The Following 2 Users Say Thank You to Jon For This Useful Post:
    baja (Jul 12, 2019), Scotsman Hosie (Jul 13, 2019)
    Perth Ontario Canada
    Where's the lawn mower motor?
  9. #7
    A few years ago I modified the cart to a 3 wheeled design with a steerable pull handle removing the front casters as they had a tendency to go the direction they wanted but not both in the same direction I have a golf cart tire for the front wheel now and it is so much easier to move around
  10. The Following User Says Thank You to Frank S For This Useful Post:
    mwmkravchenko (Dec 27, 2021)
  11. #8
    Nice! Thanks Frank.
  12. #9
    Mar 2020
    Most of my workshop machines move on airless/ solid rubber tires. No matter how long the machine is left idle -could be years- when the time comes to roll the machine, it rolls instantly. Never have to worry about flat tires that need air. For the same tire diameter, a 10-inch solid rubber wheel may have a load capacity of double that of an equal size air tire.
  13. The Following User Says Thank You to mansworld For This Useful Post:
    mwmkravchenko (Jun 22, 2023)
  14. #10
    Quote Originally Posted by mansworld View Post
    Hard to argue with that. Problem is that they are not so easy to find.
    Mark
    Download plans for welding carts.
  15. The Following User Says Thank You to mwmkravchenko For This Useful Post:
    mansworld (Jun 22, 2023)
