Thank you for your valuable input. I am familiar with heat treating processes but not the specific temperatures as those are available in reference materials. My first introduction to the processes came through my uncle who was a metallurgical engineer. I still have his collection of technical reference materials, BUT, I have do not know specific types of steel I have collected. My actual working experience comes from 35 years of teaching Industrial Technology. Some of those years were spent introducing students to industrial processes, among those processes; machining, forging, casting, annealing, hardening, tempering. We did not have any sophisticated equipment. As you mentioned we annealed by heating in the gas forge to a certain color, turning off the forge, and covering the vent hole with a firebrick.
Our heat treating was simply, heat in the forge, watch the color, quench in water, emery off the scale, and temper over a hot hunk of iron while watching the colors move down the shaft of the screw driver or chisel. I realize it needs to be a much more precise process for most manufactured products that need heat treatment.
In my situation, I have done repairs on heavy equipment for years, I have a considerable pile (100's of pounds) of worn or broken pins, large broken axle shafts, leaf springs, worn cutting edges from earth working equipment, worn or broken hydraulic cylinder shafts, etc. All of this is good steel, but too hard to machine with my capabilities.
I should have been more specific, the main purpose for oven is to be able to anneal this steel. I may in the future be able to do hardening and tempering, but the first step in this is getting the steel annealed.
From your comments on temperature variations in the furnace due to corners, etc, I am thinking that the more rounded shape of the chamber will be a good thing. The only 90˚ corners will be at the top and bottom. Do you feel there will be a much more significant difference in temperature with the vertical vs horizontal? The completed chamber will be about 6" dia, X 9" long. I have enough materials to make 2 chambers so I can stack them if necessary to make the chamber 18" long.
John
