Results 1 to 10 of 12
Thread: Self Contained Snowblower for Bobcat 310
    Lake Tahoe
    IntheGroove's Tools
    I built a snowblower for my Bobcat skid steer. I started with a couple of old Ariens snow blowers that I chopped up and welded back together to make a 54 inch unit. After trying different engines I settled on a Predator 670cc v twin rated at 22hp. I removed three of the six blades from the impeller, replaced the steel drive shaft with a Monel 400 prop shaft from an inboard boat. I made the shaft longer to add another bearing. Shaft is driven by a size 60 o-ring chain, no clutch. The chute has been lengthened and the chute guide was replaced with a tapered unit to throw the snow farther. The chute rotation is handled by a 12 volt seat motor and the chute guide is moved by a hydraulic ram connected to modified trim tab pump. Controls for the engine and chute are in the cab. This thing works quite well...
    Self Contained Snowblower for Bobcat 310-img_1847.jpg Self Contained Snowblower for Bobcat 310-img_1846.jpg Self Contained Snowblower for Bobcat 310-img_1845.jpg
    Self Contained Snowblower for Bobcat 310-img_1899.jpg Self Contained Snowblower for Bobcat 310-img_1898.jpg
    Self Contained Snowblower for Bobcat 310-img_1900.jpg Self Contained Snowblower for Bobcat 310-img_1901.jpg
  2. The Following 6 Users Say Thank You to IntheGroove For This Useful Post:
    baja (Jan 28, 2021), Captn Roy (Feb 8, 2021), Crusty (Jan 27, 2021), ibdennyak (Jan 27, 2021), Jon (Jan 27, 2021), KustomsbyKent (Jan 27, 2021)
    Dry Gulch, Tx
    Crusty's Tools
    A well done project making a thing that's useful.
    Extra props for using "chute" instead of "shoot" in your write up and even more props for doing the right thing with a boat - disassembling it for parts.
  4. The Following User Says Thank You to Crusty For This Useful Post:
    IntheGroove (Jan 27, 2021)
    Lake Tahoe
    IntheGroove's Tools
    And since I mounted the blower in the bucket I had to make a new bucket. Built it last week with steel I had on hand...
    Self Contained Snowblower for Bobcat 310-img_1839.jpg Self Contained Snowblower for Bobcat 310-img_1840.jpg
    Self Contained Snowblower for Bobcat 310-img_1841.jpg Self Contained Snowblower for Bobcat 310-img_1842.jpg
  6. The Following 2 Users Say Thank You to IntheGroove For This Useful Post:
    Captn Roy (Feb 8, 2021), Crusty (Jan 29, 2021)
    hemmjo's Tools
    Quote Originally Posted by IntheGroove View Post
    ...snip, Built it last week with steel I had on hand...
    I obviously need a MUCH BETTER "had on hand" pile!!!!!!
    Nice job on the blower.
  8. The Following User Says Thank You to hemmjo For This Useful Post:
    IntheGroove (Jan 28, 2021)
    Thanks IntheGroove! We've added your Bobcat Snowblower Attachment to our Farm and Garden category,
    as well as to your builder page: IntheGroove's Homemade Tools. Your receipt:
  10. The Following User Says Thank You to DIYer For This Useful Post:
  11. #6
    Dry Gulch, Tx
    Crusty's Tools
    Hang in there ITG - I know it's discouraging to be ignored by the angle grinder and glitter crowd when you've successfully completed an extended project making something with significant utility but at least you'll get some satisfaction from moving a bunch of snow out of the way.
  12. #7
    Lake Tahoe
    IntheGroove's Tools
    The blower has been getting a good workout these last few days. Over four feet so far...
  13. #8
    Dry Gulch, Tx
    Crusty's Tools
    That's one of those implements that isn't appreciated until it's needed and then it's a godsend. If it's a struggle just to move around then not much else gets done.
  14. #9
    hemmjo's Tools
    If you have a place to blow the snow, (no houses or windows, etc to damage) and can control where the discharge goes a blower is much better than a pusher for driveways, etc.
  15. #10
    Lake Tahoe
    IntheGroove's Tools
    The blower is the best way to remove snow around here. All of the commercial companies use blowers and the push plows are used mainly for roads and large parking lots. Even then they will bring in a blower to clean up. The county first runs the grader then the rotary...
    Self Contained Snowblower for Bobcat 310-img_1909.jpg Self Contained Snowblower for Bobcat 310-img_1908.jpg
