Results 1 to 7 of 7
Thread: Some ideas for heat shrink tube
    Supporting Member jere's Avatar
    Feb 2015
    jere's Tools
    a while back I bought some assorted size heat shrink tubing from harbor freight. some of it was much larger diameter than I could use. so I have found it works well for adding pocket could to flashlights and pens that have had the originals snap off or just didn't come with clips. it also works to add keychains or loops to stuff you might want to hang up.
    for all of the above I dipped the object in contact cement or used hot glued to keep the shrink tube from sliding off. for the key chain ends I think the tubingng and clamped the open end in a vise while still hot. then punched a hole in the shrink tube after it cooled. pretty simple cheap idea that could work for a lot of different things so hopefully some one else can use this idea too.
    if anyone else has some uses for heat shrink tube please share as wellClick image for larger version.
  2. The Following 18 Users Say Thank You to jere For This Useful Post:
    Altair (Aug 23, 2015), Andyt (Dec 28, 2019), baja (Dec 28, 2019), billster (Apr 15, 2018), grandviewdoug (Nov 19, 2017), Grumpyoldman (Feb 16, 2016), gunsgt1863 (Apr 18, 2018), gustave (Feb 29, 2016), j.bickley (Nov 18, 2017), Jon (Aug 11, 2015), kbalch (Aug 11, 2015), lazarus (Jul 11, 2016), Paul Jones (Aug 12, 2015), PJs (Aug 12, 2015), rlm98253 (Nov 18, 2017), thevillageinn (Dec 28, 2019), Toolmaker51 (Nov 18, 2017), WoodChip (Feb 6, 2016)
