Thread: spanner head bolt
    spanner head bolt
    Ever try to locate a 1/2" bolt with a 2" diameter flat head?
    if you find them let me know.
    Until then I'll have to make my own
    starting with a 1/2" bolt bussing the head down to about 1/8" in thickness very minorly rounding the hex sides then welding a hardened washer to them
    I use a 1/2" coupling nut as the collet
    Place the bolt in the holding fixture
    Then clamp the washer with spanner holes drilled in it on the fixture
    A little welding and I have made some special bolts
  2. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    NortonDommi (Mar 8, 2022), Sleykin (Jun 8, 2022)
