Results 1 to 7 of 7
Thread: Table for vertical sawing on 4 x 6 bandsaw
  1. #6
    hemmjo's Tools
    Quote Originally Posted by mdhatter3 View Post
    It would be nice if you showed pictures of the way you constructed this. And described each step.
    The photo shows every detail you could possibly need. If you click on the photo, it enlarges and shows the construction details very clearly. If you download the photo, you will find the raw image is 20" x 25", which is probably larger than the real table. Enlarged to that size you can see all of the details you could possibly need.
    You can even estimate sizes of things based on what you know. Knowing he used 4 x 4 x 1/4 angle for the column, you can guess the base is about 1/4 x 4 x 5. Which is close enough as you will need to make yours to fit your application.
