Results 1 to 8 of 8
Thread: Thread Cutting Change Gear Calculator
Hybrid View
    Stockholm, Sweden...
    DIYSwede's Tools
    Thanks for sharing, Nigel. Works great.
    Note to Metric users: -Only remember to enter a decimal point (instad of a comma) for Metric leadscrew pitch.
    My two cents: Personally I almost always need to know the change gear combo to reach (or nudge) my desired thread cutting pitch,
    rather than the other way around: Enter all the gears to find out what pitch I'll get then.
    Keep up the good work!
    Johan
    PS: I've thus far been satisfied with Dr Al's Mini Lathe Gear Calculator
    (particularly when cutting Imperial threads on my Metric mini lathe, by just 3D print a few extra 21, 50 & 63 T gears):
    https://www.cgtk.co.uk/metalwork/cal...ears/minilathe
  2. The Following User Says Thank You to DIYSwede For This Useful Post:
    editor@glue-it.com (Dec 15, 2021)
    Apr 2017
    UK
    editor@glue-it.com's Tools
    Johan
    Hello Johan,
    Thanks for the feedback. Based on this I've added a change gear calculation sheet to my workshop calculations download (free download for all)
    This now has a calculator as per the online page.
    Plus a calculator where you enter the thread pitch you want to cut, the leadscrew pitch and then 3 gear options for each position on the gear train. This then calculates all combinations, highlighting the exact matches green and any with <2% ratio error in amber.
    I need to perhaps write some more notes, but hope this helps.
    Best regards, Nigel
  4. The Following User Says Thank You to editor@glue-it.com For This Useful Post:
    Toolmaker51 (Dec 23, 2021)
    Apr 2017
    UK
    A snapshot of the worksheet here:
    Jun 2021
    Nigel:
    Thank You for posting!!!
    My 1908 Reed leaves me guessing most of the time. After a century of use the "standard gears are very worn or missing all togeather, so some very unusal combinations are required, and your varibles take the ?? out.
    I hadn't thought of using "printed" gears can you suggest a particular grade/ type of plastic to use? How about aperson that has done gears sucessfully?
    Many thanks,
    2-hack
    DIYSwede's Tools
    Quote Originally Posted by 2-hack View Post
    Many thanks,
    2-hack
    @2-hack : For me ordinary PLA gets the job done. YMMV.
    My page on this: Imperial threads on a Metric lathe.
    Thanks Nigel for sharing!
    ATB
    Johan
