Thread: Threading die starting method
    hemmjo's Tools
    When cutting male threads, the first few threads are not well formed until the die get a good grip on the part to pull itself forward.
Name:	01 first threads.jpg
    I use this method to cut good threads from the beginning.
    Mount a headless bolt of the proper thread in the tail stock chuck. Mount the part to be threaded in the lathe chuck.
    Place the die stock on the part and thread the die onto the bolt mounted in the tail stock.
Name:	02 die starter.jpg
    Then press the bolt against the part
Name:	03 touch ends.png
    Slide the die stock onto the die and thread the die off of the bolt and onto the part.
Name:	04 cut threads.jpg
    Remove the well threaded part from the chuck.
Name:	05 finished threads.jpg
  2. The Following 16 Users Say Thank You to hemmjo For This Useful Post:
    baja (Apr 18, 2025), bruce.desertrat (May 7, 2025), Carnel (Apr 15, 2025), dgbreggin (May 3, 2025), ductape (Apr 13, 2025), eimerbuilt (Apr 15, 2025), emu roo (Apr 15, 2025), fergiomaria (May 8, 2025), Jon (May 5, 2025), mtsintra (Apr 15, 2025), odd one (Apr 19, 2025), Philip Davies (May 18, 2025), philippacificnw (May 7, 2025), rebuilder1954 (May 12, 2025), rgsparber (Apr 15, 2025), uv8452 (Apr 15, 2025)
