C-bag' my Ford which my wife named the Beast only has a 169" WB. My 81 that I built mostly from ground up had a 176" wb Like I said I had extended the Pittman arm length and shortened the stops with the big heavy cat V8 I went with 15/16" diameter rod for the coil springs with 1.75 more coils instead of the factory 7.8" diameter rod this worked out very well with the additional 800 lbs of the 10.4 liter engine plus the added weight of the 10 sp road ranger and the spicer 2 sp over the original 7.3 and automatic it had in it.
Your comment about the rollovers of SUV's can be summed up with 3 words impatient inexperienced drivers, almost all late model SUV's and particularly the taller ones have a bad over-steer problem. This can be attributed largely to the all tooooooo young automotive engineers with little to no racing background. Especially no dirt track, they try to design as near to "0" camber as possible for ease of handling at very low speeds. like getting into and out of parking spaces. If you will notice many of the SUV's that are involved in roll-overs have rack & pinion power steering this system is both good and very bad at the same time. the good is the entire system can be designed lighter and occupy much less space.. The bad is most of the road feel is eliminated when making a turn at speed there is zero change in the counteractive torque felt in the steering wheel another extremely bad thing was the invention of antilock braking systems. Suddenly after that junk became mandatory on all vehicles drivers no longer learned respect for following and stopping distances. ABS systems should actually take one more leap and become smart systems with higher and lower functionality in certain traffic, weather and road conditions.
I remember once when riding with a good friend of mine in his brand new at the time 89 BMW 735I the road was covered with several inches of snow with a layer of solid ice under that. we were rolling along about 70 MPH when he suddenly said you just have to see how well this new ABS works, then he folded his arms in his lap and stomped down as hard as he could on the brakes the car did make a safe very controlled stop in a most reasonable distance for the road conditions.
I told him that soon there would be a new set of young drivers to come along who would take the ABS for granted and not learn how to make a controlled stop in adverse road conditions then there would be more accidents causing more damage to the vehicles than ever before because the internal crumple zones would be so well designed that the whole rest of the vehicle would become little more than an energy absorbing buffer to protect the occupants at all cost.
To this day I still say that ALL learning drivers both young and not so young should never be allowed to get their permit until they have both driven a vehicle manufactured before 1950 and ride in the cab of a fully loaded Semi tractor and trailer with a 150,000 lb piece of over-sized equipment on the trailer for 10 hours in city freeway traffic, then they must pass a test of 200 random questions about their experiences in both vehicles before taking their road test.
OK! my tirade is complete.
