10 Attachment(s)
Travel Tool Chest & Workbench with Integrated Vice
Attachment 46709
This is a combined tool chest and workbench. It is made out of Sweet Chestnut and American Black Walnut (along with a lot of brass and stainless steel). All of the woodwork was done with hand tools (except for a few instances of resawing with a bandsaw). All the metalwork was done with power tools (because hand tool metalworking is just silly!).
I did this project mainly as a means of practising hand tool woodwork. However, it's also intended as a means to take my hobby on holiday. My other half has M.E. and often needs time to rest. I'd go spare if I just sat around reading a book while she rested, so being able to take a basic (ish) woodworking kit with me keeps me amused and sane!
Attachment 46710
This is what it looks like with the front opened. The drawers hold the various tools I would need for making simple wooden boxes and suchlike. The front of the box doubles as a shooting board for shooting square edges or mitres.
Attachment 46711
This photo shows the back of the chest and the vice (which has a leather jaw). The uprights give a firm surface to clamp against while (hopefully) allowing for wood movement by having narrow slats rather than a solid back. The diagonal piece is there to stop racking when planing on the top surface of the chest.
Attachment 46712
This photo shows the planing stops in use for planing the top surface of a board.
Attachment 46713
The vice holds boards rigidly for sawing (or planing on the edges or ends).
Attachment 46714
Wide boards can be held by removing the middle vice screw.
Attachment 46715
The vice can also be flipped round so the leather jaw is facing outwards and the vice screws go into slotted holes. It can then be raised, providing a stop, so boards can be fully constrained while giving access to the complete top surface.
Attachment 46716
The vice jaw can also be completely removed and big boards clamped to the back (they can also be clamped to the top, obviously).
Attachment 46717
This photo shows the shooting board in use for shooting an end square (with home-made block plane).
Attachment 46718
The shooting board gets turned round for shooting mitres.
There are lots more photos of the chest on my website if anyone's interested: https://www.cgtk.co.uk/woodwork/hand...raveltoolchest
I mentioned that this was an opportunity to practice hand-tool woodworking skills. I've learnt a huge amount over the year it took me to make this (in my spare time). This was:
- The first project in which I've made panels from rough sawn wood by hand. In the past I've made panels, but they've involved a table saw (which I'm very happy to have now sold!) and/or thicknesser (which I've still got, but it's nice to be able to work without it, especially given the amount of snipe from my cheap-ish thicknesser). I've planed wood to size by hand in the past, but only relatively small pieces (for boxes) and this is the first time I've had to make lots of pieces of wood square edged and the same size.
- The first project where I've cut dovetails without any sort of saw guide. I've cut quite a lot of dovetails with 3D printed saw guides and I've cut a few (not very successful) dovetails without the guides on bits of scrap wood for practice, but this is the first finished project that includes guide-less dovetails. Also the first time I've cut dovetails on such thick wood: all previous ones have been on box-scale projects, so 10-ish mm thick rather than 20 mm thick.
- The first project in which I've cut housing joints (for the middle upright support and the drawer runners) - known as dadoes in America I believe.
- The first project with wedged through mortice-and-tenon joints (for the rear uprights). I used blind mortice-and-tenons on my side table, but the tenons were cut with a table saw and the fact that the mortices are blind makes them a lot easier! I'd done a few practice joints (with varying levels of success!) in offcuts, but never used them in a project.
- The first project with half-lap dovetails (for the drawer fronts). I'd done exactly one practice piece before starting this project.
- The first project with wooden drawers. Unless you count pocket-hole joined plywood boxes with ball-bearing slide runner things, I'd never made a wooden drawer before this project.
- The first project with half-lap joints (on the anti-racking diagonal piece on the back).
- The first project in which I've used protein-based glue (most joints with fish glue and some with TB hide glue).
- The first project where I've had to come up with my own way of dealing with wood movement. On previous projects I've just used well-known techniques (buttons for table tops, grooves for box bases), whereas making what is essentially a five sided box where all sides needed to be rigid took a bit more thought. Hopefully what I've done will last.
- The first time I've used a "Dutchman" / graving piece to repair a blemish. I used two different types of Dutchman: decorative butterfly ones in a contrasting wood and discrete grain matched ones.
- The first large project I've finished without sandpaper. The faces were finished with a smoothing plane without any of the dust and tedium of sanding (and I think it looks a lot better for it!). A scotchbrite pad was used for rubbing between coats of finish ("Mike's Magic Mix": equal parts pure tung oil, satin varnish & white spirit) but that's a quick job compared with sanding large surfaces.
- The first time I've tried photolithography (for etching the numbers that are inset into the top of each drawer front to help re-fit them in the right place as they're removed when the tool chest is in use).
- The biggest and most complicated hand-tool project (and woodworking project in general) I've done. I did use a bandsaw for some bits of resawing, but all the other woodwork was by hand. Metalwork was all powered, but that doesn't bother me as I hate filing and don't even aspire to being a hand-tool metalworker. Woodwork power tools are noisy and dusty, but most metalwork power tools I use aren't (angle grinders being the obvious exception). Welding the planing stops without some sort of power source would have been quite a challenge!
