Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Turning Matching External/Internal Tapers
    Another way to measure a hole like the exit of an internal taper is to measure how far a precision tooling ball seats into the hole, then do a bit of mathematics to obtain the diameter of the hole.
    The accuracy of this method depends heavily on the condition of the hole edge. There can be no chamfer or burs and the ball can not be pressed into the hole.
    The associated math looks like this...
    Let:
    R = radius of tooling ball
    H = distance ball descends into hole
    D = diameter of hole
    Then:
    Z = R - H
    A = 2 * ACS (Z/ R)
    D = 2 * R * SIN (0.5*A)
  2. #12
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Quote Originally Posted by mr herb View Post
    Mrehmus2.
    You have mentioned a very significant part of angle cutting.. Any tool that you use , Indicator or cutting point of tool bit must be on dead center of the lathe. Rick does this with the indicator, altho he is doing it almost subconsciously, because he has done it so often, but doesn't mention the tool point..
    Otherwise, a magnificent presentation, Rick!
    mr herb
    I updated the article to show me first setting the cutter on center. You are right, it didn't occur to me to even mention this step.
    Rick
    Rick
  3. The Following User Says Thank You to rgsparber For This Useful Post:
    Jon (Dec 5, 2019)
  4. #13
    Thanks rgsparber! We've added your Matched Taper Turning Method to our Machining category,
    Download plans for lathes.
