Results 1 to 10 of 17
Thread: Universal Grinder Power Feed xy table power feed
    jjr2001's Tools
    I finally got the time to put my power feed on my universal grinder. It will be used any time the x position needs to be changed. Manual feed from the opposite end is still useable but it considerably stiffer with the motor engaged. It only required 4 new pieces of aluminum to complete the project. It is now ready for power.
    Here is a link to the "Universal" Grinder which uses the xy table. Parts for the motor drive are listed there.
    http://www.homemadetools.net/forum/s...9982#post71647
    JR
    Attached Thumbnails Attached Thumbnails Universal Grinder Power Feed xy table power feed-dscf0001.jpg   Universal Grinder Power Feed xy table power feed-dscf0002.jpg   Universal Grinder Power Feed xy table power feed-dscf0004.jpg   Universal Grinder Power Feed xy table power feed-dscf0005.jpg   Universal Grinder Power Feed xy table power feed-dscf0006.jpg
    Universal Grinder Power Feed xy table power feed-dscf0007.jpg   Universal Grinder Power Feed xy table power feed-dscf0008.jpg   Universal Grinder Power Feed xy table power feed-dscf0010.jpg   Universal Grinder Power Feed xy table power feed-dscf0011.jpg
  2. The Following 12 Users Say Thank You to jjr2001 For This Useful Post:
    emu roo (Nov 4, 2024), freddo4 (Jul 7, 2020), Home-PC (Mar 1, 2021), Jon (Sep 22, 2016), mwmkravchenko (Jul 30, 2022), Okapi (Sep 22, 2016), olderdan (Sep 17, 2018), Paul Jones (Sep 16, 2016), PJs (Sep 21, 2016), scoopydo (Sep 21, 2016), thoms_here (Dec 28, 2017), Tule (Dec 27, 2017)
    jjr2001's Tools
    Control Box For Universal Grinder Table Feed
    I have a few shots of the "portable" feed motor power supply. I will use this on the lathe feed screw(not done yet) and on the Universal Grinder power feed. The parts are the same as used on the Mini Mill power feed with the exception of the plastic box. The 15 vdc power supply brick is simply epoxied on to the box. The mill unit is mounted on the spindle housing in a more permanent position as I use it all the time. On the lathe and grinder I will not be using it all the time so I went for a portable method.
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Universal Grinder Power Feed xy table power feed-dscf0012.jpg   Universal Grinder Power Feed xy table power feed-dscf0013.jpg   Universal Grinder Power Feed xy table power feed-dscf0014.jpg
  4. The Following 7 Users Say Thank You to jjr2001 For This Useful Post:
    Home-PC (Jul 13, 2022), Jon (Sep 22, 2016), olderdan (Sep 17, 2018), Paul Jones (Sep 16, 2016), PJs (Sep 21, 2016), scoopydo (Sep 21, 2016), Tule (Dec 27, 2017)
    Thanks jjr2001! We've added your Grinder Table Power Feed to our Electrical category,
    Thanks jjr2001! We've added your Power Feed Controller to our Electronics category,
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Nice clean build JR. A thought for the hand wheel/motor coupling issue. Perhaps if you cut your coupler in 2 and milled a couple of flats for a small plate and thumb screws you could uncouple the gear motor with a drop latch of some kind...of course you would have to align it again to recouple. Just thoughts...
    Thanks for sharing this great build. ~PJ
    Mark Twain
  8. The Following User Says Thank You to PJs For This Useful Post:
    jjr2001 (Sep 21, 2016)
    jjr2001's Tools
    Thanks PJ, Great idea. Should be able to fit that right in. Thanks again, JR
  10. The Following User Says Thank You to jjr2001 For This Useful Post:
    PJs (Sep 22, 2016)
  11. #7
    Dec 2016
    Ralphxyz's Tools
    I have seen a post of a motorized X table on a mill. They used a sliding socket to engage and disengage the motor, real simple.
    I'll have to see if I can the page again.
    Ralph
  12. #8
    Saskatoon, SK.
    RickT's Tools
    Nicely done!
    I borrowed the idea from a u-tube video for a very nice sliding coupler and variable speed , two direction controller for my mill. Works great! Have a peek at his video and it may inspire you as well.
    Keep on building!
    Rick
  13. The Following 3 Users Say Thank You to RickT For This Useful Post:
    desbromilow (Dec 4, 2024), Home-PC (Jul 13, 2022), NickP (Dec 27, 2017)
  14. #9
    Dec 2016
    Ralphxyz's Tools
    Quote Originally Posted by RickT View Post
    Nicely done!
    Keep on building!
    Rick
    Thanks Rick that was the video I was thinking about.
    It really is a great idea for engaging and disengaging the drive motor.
    Ralph
  15. The Following User Says Thank You to Ralphxyz For This Useful Post:
    Paul Jones (Dec 28, 2017)
  16. #10
    jjr2001's Tools
    Thanks for the tips guys. That manual clutch is the way to go.
    Cheers, JR
