Results 1 to 10 of 12
Thread: Using cling film, one size fits all
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    This is a method I use for stopping tiny screws falling of the end of the screwdriver before they have even got close to the work piece. I simply go to the kitchen take the cling film, tear a small piece off, push the screw into the film with the screw driver and wrap the cling film around the screw and driver. Once started in the hole simply pull the cling film away and finish screwing into place.
ID:	34585 10BA x 1/8”
ID:	34586 Screw and screwdriver ready to be wrapped
ID:	34589 Starting screw
ID:	34591 Then pull the cling film over screw head and then tighten.
    This works with all types of screws, bolts, wood screws etc. where the fastener needs to be held in place to get it started. I have even used it in conjunction with a socket set to retain bolts or nuts. This is a really easy fix for those difficult to get to threads.
    Thank you for viewing
    The Home Engineer
ID:	34587   Click image for larger version.
  2. The Following 37 Users Say Thank You to thehomeengineer For This Useful Post:
    Andyt (Apr 22, 2020), arwan1953 (Sep 20, 2022), baja (Apr 22, 2020), benkeller3 (Apr 21, 2020), Beserkleyboy (Apr 21, 2020), bgerens (Apr 19, 2020), BuffaloJohn (Sep 21, 2022), ChasW (Apr 23, 2020), Dimsa (Apr 26, 2020), DIYer (Apr 20, 2020), Drew1966 (Apr 26, 2020), emu roo (Jul 3, 2024), EnginePaul (Sep 29, 2023), flyfr8rs (Sep 21, 2022), garage nut (Apr 21, 2020), hegefer (Apr 22, 2020), jimfols (Apr 21, 2020), Jon (Apr 23, 2020), lassab999 (Sep 20, 2022), llh49 (Apr 28, 2020), Moby Duck (Oct 27, 2023), neilbourjaily (Apr 21, 2020), Paul Jones (Apr 22, 2020), Philip Davies (Apr 22, 2020), Quinton 357 (Apr 24, 2020), rgsparber (Apr 21, 2020), Rikk (Apr 22, 2020), sandra1963 (Oct 3, 2023), Scotsman Hosie (Oct 1, 2022), Scotty12 (Apr 26, 2020), Seedtick (Apr 21, 2020), Shaper (Sep 21, 2022), sossol (Apr 27, 2020), thevillageinn (May 10, 2020), Tooler2 (Apr 27, 2020), Toolmaker51 (May 3, 2020), verticalmurph (Apr 21, 2020)
