Results 1 to 10 of 12
Thread: Vertical shear finishing tool for the lathe - video
    Vertical shear finishing tool for the lathe. By Steve Jordan. 9:31 video:
  2. The Following 9 Users Say Thank You to Jon For This Useful Post:
    Carnel (May 2, 2022), Christophe Mineau (Apr 29, 2022), Floradawg (Apr 28, 2022), Home-PC (Apr 29, 2022), mwmkravchenko (May 9, 2022), NortonDommi (Apr 28, 2022), old_toolmaker (Apr 28, 2022), Tonyg (May 9, 2022), uv8452 (May 21, 2022)
    North Island, New Zealand.
    NortonDommi's Tools
    I have a couple of those Eccentric Engineering tangential tools and find they do an excellent job as a shear tool when used in reverse i.e. with a RH tool instead of running towards the headstock cut towards the tailstock and vice versa for a LH tool.
    The bit could also be turned through 90 degrees to achieve the same result, I have been means to make a dedicated tool though.
    Dec 2017
    Cape Coral, FL
    old_toolmaker's Tools
    Nice video and post!
    I figure I am eccentric enough to make my own. So I did, but I seldom use it.
    Thanks for posting!
    Dick
    Links to some of my plans:
  5. The Following User Says Thank You to old_toolmaker For This Useful Post:
    Jul 2018
    Flora, MS
    Floradawg's Tools
    Great info. Is the traditional cutting speed the same for this tool? Thanks.
    Apr 2021
    Thanks Steve
    Hi Steve. Do you have any thoughts to share about the sensitivity of the finish to different speeds and feed rates? In your examples you look like you're turning at quite a low speed but moderate feed rate.
    Regards
    Andrew
    Quote Originally Posted by NortonDommi View Post
    I made an indexable carbide tip version by machining the sides of the tool holder to 15 deg. There is a full description here
    Shear tools for lathe work.
    Vertical shear finishing tool for the lathe - video-sheartool-01.jpg Click image for full size.
  9. The Following 5 Users Say Thank You to tonyfoale For This Useful Post:
    Christophe Mineau (Apr 29, 2022), mwmkravchenko (May 9, 2022), NortonDommi (Apr 29, 2022), old_toolmaker (May 1, 2022), Tonyg (May 9, 2022)
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    The shear tool is extremely useful for obtaining very close tolerance finishes, down to exactly on size.
  11. The Following 2 Users Say Thank You to Hans Pearson For This Useful Post:
    mwmkravchenko (May 9, 2022), old_toolmaker (May 10, 2022)
  12. #8
    One could create a formula, though a clear method escapes me. Perhaps recording of result is a better term.
    Any rate, shearing differs from conventional turning that periphery and cutter are close to alignment, instead perpendicular. Spiral of chip shows that, something (barely) like a drill bit.
    The lowered speed, high feed is a low temperature cut; transverse cut engages marginally wider area like deeper cut with radius tool. The finish might improve lowering feedrate more, with a diminishing return.
    Job shop wise, we ground the bits on a surface grinder, stoning the leading edge. Without access to a rubber roll grinder, this worked on feed spools, like no perpendicular might.
  13. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
  14. #9
    Supporting Member Bony's Avatar
    May 2015
    Tasmania, Australia
    Bony's Tools
    I noticed some chatter whilst turning that you quickly averted. That suggests to me either a lack of rigidity (which doesn't seem to be the problem) or that the tool bit is no longer cutting but simply rubbing, which of course needs to be avoided. Any comments?
  15. #10
    Dec 2017
    Cape Coral, FL
    Vertical Shear Tool
    In my own experience these vertical shear tools don’t do a good job of turning to a square shoulder. Am I expecting too much of this tool?
    Dick
