Results 1 to 10 of 16
Thread: Wire Bender
    Supporting Member kess's Avatar
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    Wire Bender
    Wire Bender mini tool.
    Suitable for wire bends up to Ø4mm as well and sheet metal strips (steel, stainless steel, aluminum, brass, copper, tin can)
    by the addition of one small cylinder with internal dia 4mm over the shaft.
    Materials: one set M16 bolt/nut, a broken drill bit Ø4mm and a piece of flat bar 15x3mm.
    For bigger wire diameters is needed the use of a bigger size bolt/nut than M16 or 5/8".
Name:	First frame_YT.jpg
ID:	32530 Click image for larger version.
ID:	32532 Click image for larger version.
ID:	32509 Click image for larger version.
ID:	32511 Click image for larger version.
ID:	32513 Click image for larger version.
    Bolt nut M16. Using an Ø3.5mm drill bit do a hole from side to side.
ID:	32515 Click image for larger version.
ID:	32517 Click image for larger version.
    Do at first a cut at the nut's center till the hole
ID:	32519 Click image for larger version.
    and then a second cut removing the half 1/3 of the nut.
ID:	32521 Click image for larger version.
    Cut the bolt at center till the hole.
ID:	32523 Click image for larger version.
ID:	32525 Click image for larger version.
    Mark the nest hole for the shaft.
ID:	32527 Click image for larger version.
    Use a file to clean up the letters and numbers.
ID:	32529 Click image for larger version.
    Use at first an Ø3.5mm drill bit and then an Ø4mm to make a nest hole with 15mm depth.
ID:	32535 Click image for larger version.
    Cut of from the broken Ø4mm drill bit the needed piece and then weld the handle at the nut.
ID:	32537 Click image for larger version.
    I have used a piece of brass and a piece of aluminum foil for threads protection.
    Some bends are available on my YouTube vid.
  2. The Following 11 Users Say Thank You to kess For This Useful Post:
    emu roo (Oct 12, 2022), hansgoudzwaard (Dec 22, 2019), high-side (Dec 17, 2019), Jon (Dec 13, 2019), nova_robotics (Oct 16, 2022), Okapi (Mar 27, 2020), old_toolmaker (Oct 8, 2023), PowerMk (Jan 29, 2020), Resident114 (May 28, 2023), shopandmath (Dec 13, 2019), thehomeengineer (Jan 27, 2020)
