Results 1 to 7 of 7
Thread: Wooden thumb planes / rabots noisette
Hybrid View
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    My personal build of thumb planes.
    Funny enough, thumb plane translates "rabeau noisette" in French, which means hazelnut plane.
    They are simply made from a tutorial I found on the Web.
    The first ones, I did them using the hard wood I had : chestnut tree, but turned out to be too soft.
    For the second attempt, I found in an antique shop an old wooden planer, made out of sorb tree (I dont know if that translation is good, it's "cormier" in french), that red , very hard wood.
    It is indeed the traditional wood here for making plane soles.
    So, I cut a little length in that maxi plane to make several of my mini planes
    And they are far better.
    The blocks are made of ebony for the first.
    I have several width, and some have a flat sole, others round sole.
    Tell me what you think !
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    kbalch (Aug 25, 2014)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Christophe! I've added your Thumb Planes to our Woodworking category, as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
    Beautiful set Christophe. Excellent work.
    Hi Christophe, where do you use such a plane?
    Jul 2014
    France, Brittany !
    Hi ,
    The curved sole planes are used mainly to carve the plates for archtop instruments (violin, mandolins, jaz guitars), but personnaly, since I have made the wooden ones, I have purchased a set of brass ones.
    They are used after roughing with a gouge or possibly a router, and before the scraper (very few sand paper use indeed in the traditional building process)
    For the curly maple, you need to use a toothed blade, standard blade for spruce.
    Example on this photo (credit : found on the web) :
    The flat sole little planes are useful to shape the edges of the plates and also the braces of top plates, where you need to follow a curve you could'nt follow with a longer sole plane.
    like on this photo (credit : found on the web) :
    I still use my wooden planes for the flat soles.
    Cheers !
    Christophe
  7. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    DIYer (Sep 10, 2014)
    Thanks for the explanation, Christophe! That bit about using little sandpaper in traditional work is interesting.
  9. #7
    Jul 2014
    France, Brittany !
    Yes, and on that last point, to be very traditional, ancient builders and still modern ones use this instead of sand paper.
    Japanese craftsmen use also something similar.
    Cheers !
    Christophe
