Results 1 to 10 of 322
Thread: 1974 XS/TX650 rebuild
    Oct 2015
    th62's Tools
    Well, I finally got around to finishing off the right side filter, and damn it looks good. It gives a nice unobstructed air flows, much better than pods. My plan on heating and cooling didn't work too well, much to hard to handle all the bits and pieces and tooling trying to press them together, so, I ended up pressing together cold.
    Same with the sizing, .020mm press fit was much too much, so after a few tries I got a good fit by decreasing it to about .04mm. And of course my day wouldn't be complete without misplacing parts, I lost the idle mixture screw spring, no idea where I'm going to get one of them from.
    All I have to do now is make an identical one for the left carb from that great slab of aluminium I spent yesterday tracking down, and beat up a rear plate. But first I'll make another fuel distributor block to keep the hosing neat and simple.
    If I can remember, I'll take lots of pics of the machining and fabrication process and bore you all to tears with them.
ID:	44420   Click image for larger version.
ID:	44421   Click image for larger version.
ID:	44422   Click image for larger version.
ID:	44423   Click image for larger version.
ID:	44425   Click image for larger version.
  2. The Following 3 Users Say Thank You to th62 For This Useful Post:
    greenie (Dec 21, 2022), olderdan (Dec 21, 2022), tonyfoale (Dec 21, 2022)
